givi monolock universal adapter
trichards_imp Offline
New to the Forum
Threads: 0
RE: givi monolock universal adapter
Recently, intalled Givi mounting plate to factory carrier on my '13 CB1100. Used 2 of the 4 bolts included with the kit (Z113C) which was enough in my judgement to secure it securely. The nuts are not butterfly nuts but locking style. I attached the plate so that it protrudes beyond the rear of the carrier a good couple inches. This allowed use of the 2 holes on the carrier to line up with 2 places on the mounting plate. The plate is well made of some form of hard composite and seems to be strong enough to handle the cargo weight requirements. I have a 2010 SH150i equiped with the Givi Monolock Topcase and wanted the ability to use on CB1100 as well. I am very pleased with the Givi Topcase and the mounting plate. When the Topcase is not on the bike the plate looks nice and neat. This is my first post so am just learning how to navigate and don't have pics.
[/size][/font]
Hello everyone, Does anybody know if the universal mounting plate that coes with the Givi monolock case is made of plastic or steel. It looks like it mounts to your existing rear carrier with bolts, square washers and butterfly nuts. My concern is where the square washers fit into the recess of the adapter plate. If the adapter plate is thin plastic where the square washers attach, is the thin plastic strong enough to support the box and if the plastic becomes brittle over time, will the washers pull through? If the plate is made of steel, then I could see it being very sturdy. Thanks for any input.
[/quote]
09-10-2014, 07:20 AM
Likes Given: 1,015
G'day tririchards and welcome. Why not post in the New Members section and tell us a bit about yourself and your bike?
09-10-2014, 07:57 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
The nut are nylocs, not butterfly or wing nuts. Unlike trichards above, I used all 4 of the mounting brackets on the Honda rack. After you are all mounted up, a cover plate goes in and hides the honey comb part of the mount and does look tidy and provides a flat surface. A cap is provided to cover the contacts when not used if you install a light kit.
Time will tell if the mount material holds up. I suspect it will. I wish is was aluminum like the monokey I have on the ST, but it is not.
09-10-2014, 09:45 AM
HikerToo_imp Offline
Threads: 114
geez, just one picture or url link in this thread, was all I was looking for, so maybe the rest of us knew what you are talking.....you know, a picture is worth a bunch of words type thing.
09-10-2014, 09:50 AM
fredkb_imp Offline
Threads: 30
Re: givi monolock universal adapter
Hello everyone. I received my givi monolock case E470. The case is big enough to place two full face helmets in. The case comes with the monolock adapter bracket, so you can mount the case to any luggage rack. I mounted mine to my ventura sport rack. The mounting bracket is plastic, but it seems heavy duty. The case is rated for only 6.5 lbs capacity. Ithink it will be fine for jackets, clothes, helmet, etc. I probably would load it down with groceries and not worry. Here is some pictures.
[Image: ec58b85a70408bf74790e3606dcb43bf.jpg][Image: 550f2a734b22bf6e70ab56f901f531b6.jpg][Image: 23e9ee54bad05a83866a894f3ea30d6a.jpg][Image: 56a1df9d9aea1b2ea5dcf6f76f8e66a7.jpg][Image: 33a8ce08650a2c5915eca392b3f90f56.jpg][Image: bd1d231963ea3075dc37712b048c350f.jpg][Image: f06670d4459ff74b6ba4606cc4e458a2.jpg]
09-10-2014, 11:47 AM
Lord Popgun Offline
Virginia
Likes Given: 142
#26
That should make Hiker Happy Smile
That case looks good. I got the B37 as I was afraid the 47 would be too big. And even though I have the Honda rack, its mounted just like on your rack.
Hiker, you can see the honeycomb on his bottom shot. You drop in a supplied square washer and bolt use the nyloc nut to hold the bracket. You can see Fred used all 4 and so did I. Fred does not have the light kit installed. You can tell as there is no cable and the mount knockout for the connector has not been knocked out. After the mount was all tightened up, Fred installed the top panel so it looks nice and covers up the honeycomb and all.
09-10-2014, 12:34 PM
Likes Given: 1,015
#27
That's the fitting I had on the Shadow with an OEM rack. I also used all four bolts. It was very neat and the box fitted on it very well. I tried it on the Daytona mount I bought as the box fits on it better, but the mounting to the rack wasn't quite as good.
09-10-2014, 04:07 PM
fredkb_imp Offline
Threads: 30
#28
Hello everyone. I wqs cleaning my bike today, and thought I would share with you one of the advantages of the ventura sport rack system. I recently installed a givi monolock case on the rack. If I want a more naked look, I can remove the rack, universal adapter plate and givi box in a matter of seconds. The ventura rack has a grab handle that you can pop on if you like, but I like the bare minimalist look without the grab bar, with only the mounting brackets visible. Here are some pics.
[Image: f34946fd3435abcd21100b0f14d5599a.jpg][Image: c287c04531c9f13ee3aa8ad56c988526.jpg][Image: a7f37131363be0a5771e0914ce4ce0e2.jpg][Image: 26cd4ccb0767f6c5e688a63cb07bbfad.jpg][Image: 564932ecded44f9ccc9cf1696788adbc.jpg][Image: 28f553e041fa1df7c2f9f18ecf95a9c5.jpg]
Here is grab handle installed. I like it better with no grab handle.
[Image: 298158e7a5d309e2a475ad7609817da1.jpg][Image: f365496ac432ca9ad11e2c954f2fa0ba.jpg]
09-15-2014, 08:42 AM
  Givi Airstar Universal Windshield - A660 peterbaron 2 627 12-28-2025, 02:15 PM
  Givi rack for top box. Nick_imp 6 577 01-17-2025, 03:55 PM
  Top box, Givi, Shad or maybe something else? Davidjill_imp 17 1,413 07-25-2024, 08:22 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 398 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Givi AF49 Airflow Universal Windscreen binarkansas_imp 3 412 09-23-2021, 07:02 AM
Last Post: LikeAfox_imp
  GIVI luggage help tod.branko_imp 7 747 09-14-2021, 08:04 AM
  Givi SR1118 Top Case Rack active1951_imp 4 507 06-28-2021, 07:08 AM
Last Post: Tom_imp
  MY NEW GIVI V47 MAXIMA 4 Alfgaxatico_imp 15 1,202 01-12-2021, 02:42 AM
  New Givi Airflo Mscb1100_imp 8 786 11-20-2020, 09:58 AM
Last Post: Alfgaxatico_imp
  Givi Trunk Jambo_imp 13 1,309 08-31-2020, 02:27 AM
