givi monolock universal adapter
fredkb_imp Offline
Threads: 30
Hello everyone, Does anybody know if the universal mounting plate that comes with the Givi monolock case is made of plastic or steel. It looks like it mounts to your existing rear carrier with bolts, square washers and butterfly nuts. My concern is where the square washers fit into the recess of the adapter plate. If the adapter plate is thin plastic where the square washers attach, is the thin plastic strong enough to support the box and if the plastic becomes brittle over time, will the washers pull through? If the plate is made of steel, then I could see it being very sturdy. Thanks for any input.
09-06-2014, 10:48 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 199 in 118 posts
Likes Given: 142
RE: givi monolock universal adapter
Cormanus knows.
And I should know tomorrow if UPS delivers on time...
09-06-2014, 10:50 PM
Ole Offline
Wisconsin
Threads: 18
Likes Received: 5 in 3 posts
Likes Given: 1
Both of my Givi plates are plastic. I have had them on scooters, motorcycles, dirt bikes.
They are rock solid no problems at all.
09-06-2014, 11:04 PM
Lord Popgun Offline
Virginia
Likes Given: 142
I was hoping it would be metal. The Monokey on my ST is aluminum. And it is really sturdy.
Good to know the plastic one is going to be rock solid too. Thanks Ole.
09-06-2014, 11:21 PM
Likes Received: 880 in 482 posts
Likes Given: 1,016
Fred, mine's a Monolock and plastic. It wasn't thin and was, as Ole says, solid as a rock. When I got the CB and bought a specialist Daytona rack, it came with its own plastic mounting plate. That's solid and strong too. I've bounced it around a bit and had NL problems. As it fits the rack better, I've used that.
Popgun, I don't know whether the monokey plate is different. They are, as I recall, different systems.
09-07-2014, 07:07 AM
ClassicVW_imp Offline
Threads: 6
I have a Givi on my other Honda, the NT700V.
I have both the Monokey and the Monolock plates. Both are thick, very solid, plastic.
I have both because I originally ordered the wrong plate for my top box and I couldn't do a simple exchange.
Does anyone else think the names are too similar, causing confusion?
The Monokey is the one that I don't need. If anyone needs one, I'll give you a great deal!
09-07-2014, 07:58 AM
Likes Given: 1,016
(09-07-2014, 07:58 AM)ClassicVW_imp Wrote: I have a Givi on my other Honda, the NT700V.
Yes.
09-07-2014, 08:12 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Yes they are confusing. The whole giviusa website is confusing. I ended up calling them for the info I needed and mentioned it was all confusing, and the they were, uhhhh, confused. Smile
09-07-2014, 10:35 AM
Threads: 6
Yes.
Yes.
Clap Good. I'm glad. I was worried you guys would say I was having a senior moment!
09-07-2014, 12:04 PM
Likes Given: 1,016
(09-07-2014, 10:35 AM)Lord Popgun_imp Wrote: Yes they are confusing. The whole giviusa website is confusing. I ended up calling them for the info I needed and mentioned it was all confusing, and the they were, uhhhh, confused. Smile
LOL.
09-07-2014, 05:49 PM
  Givi Airstar Universal Windshield - A660 peterbaron 2 627 12-28-2025, 02:15 PM
  Givi rack for top box. Nick_imp 6 583 01-17-2025, 03:55 PM
  Top box, Givi, Shad or maybe something else? Davidjill_imp 17 1,434 07-25-2024, 08:22 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 399 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Givi AF49 Airflow Universal Windscreen binarkansas_imp 3 414 09-23-2021, 07:02 AM
Last Post: LikeAfox_imp
  GIVI luggage help tod.branko_imp 7 757 09-14-2021, 08:04 AM
  Givi SR1118 Top Case Rack active1951_imp 4 507 06-28-2021, 07:08 AM
Last Post: Tom_imp
  MY NEW GIVI V47 MAXIMA 4 Alfgaxatico_imp 15 1,204 01-12-2021, 02:42 AM
  New Givi Airflo Mscb1100_imp 8 797 11-20-2020, 09:58 AM
Last Post: Alfgaxatico_imp
  Givi Trunk Jambo_imp 13 1,328 08-31-2020, 02:27 AM
