GIVI luggage help
tod.branko_imp Offline
Threads: 19
GIVI luggage help
As fortune would have it sometimes, I guy I know hit me up and asked me if I want a GIVI top box, and as I love freebies I said yes, and I went and picked it up. I have no experience with GIVI top boxes, I understand I need a plate to fit on a rack, and that's about it.
My question(s):
Any specific rack I should use for the CB?
Any specific rack I should use for a GIVI?
I have to say I never considered a top box, but also I don't mind it, especially this one is not too large or bulky (it's called Micro), so I'm willing to give it a shot. Any help and advice are welcome.
Thanks![Image: 21767fb8cd831cdef7d98a287773ee21.jpg]
'14 CB1100 STD 5 speed
09-14-2021, 04:10 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,209 in 519 posts
Likes Given: 981
RE: GIVI luggage help
I love my Givi top case. Very convenient, and once you have the mount on your bike, you can interchange any Givi box you'd like.
First, you'll need a Givi rack, part number SR1118
https://twistedthrottle.com/shop/luggage...eparately/
That case is either a Monolock or a Monokey. Monolock has two wide mounting tabs that protrude from the bottom front of the box. Monokey has two narrow slots under the front of the box. Depending on which you have, you'll need to add a mounting plate to attach to your rack. Then, you can just snap the box on and off, and get a newer box if your needs call for it.
Today, I rode with my V47, my larger box, as I plan to carry some large objects home from work.[/align]
Tod, I just flipped my V47 box upside down and snapped this pic. If the front bottom edge of your box has these two slots, you have a Monokey box, and you want an E251 mounting plate.
If not, you have a Monolock, and want a Z113C mounting plate. Hope this helps!
09-14-2021, 04:40 AM
Threads: 19
GIVI luggage help
Thanks Gone, that's exactly what I needed to know [Image: 0e071632dfceff6186a034919fd6ffe1.png][Image: 0a2034d2b45880ac15f4b57d88f307b3.png][Image: 8f06f81993998b674a9b034c876ebfaa.png][Image: 5b7b22489a3effdcb2c1b19267641802.png]
My box is a Monolock, it's written on it, and I did just reconfirm by looking at the extensions on the front of the case. This rack's shape worries me a little because of my modified rear mudguard, my stoplight is higher up than the stock one, I will have to somehow figure that fitment out before I spend the cash. Do you think this is the only rack option for the CB that will take a GIVI?
09-14-2021, 05:22 AM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 981
Almost any rack will do the job, as the mounting plate has multiple options for attachment. But, the Givi rack sits up pretty high, especially compared to the stock Honda rack.
I measure about an inch and a half between the top of my stock taillight and the bottom of the rack.
09-14-2021, 05:29 AM
Threads: 19
GIVI luggage help
Yes, thanks, I also just did a quick research and realized that a universal plate can be attached to basically any rack, and thank you for the pics and measurements, I'll compare to my bike and see how it lines up
09-14-2021, 05:33 AM
peterbaron Offline
Likes Given: 996
Best is to use a Honda rack for CB1100, two different types:
https://www.samurider.com/?p=18457
This one, I have on my '14 DLX
https://www.samurider.com/?p=13395
My '14 standard is equipped with this one
For Givi monokey, you should buy an universal mounting kit like this:
https://www.amazon.ca/E251-Universal-Mon...B00FYOQB5A
Givi monolock universal mounting kit looks & is different:
https://fortnine.ca/en/givi-universal-mo...are-z113c2
I have monolock mounted on two different Honda racks and transfer my only Give box between them as needed.
Note: you can buy a universal Givi kit or rack from any supplier, as long as you buy the right ones.
The third and I believe the final option is as Gin60 said.
09-14-2021, 05:48 AM
furious_blue_imp Offline
Threads: 11
My '14 CB has the Honda Factory Luggage rack. I found that it was a little tricky getting the Givi plate mounted on the rack, but there was (at least) one configuration of the mounting bolts that ended up working. Having removable locking luggage on that bike has been really handy. Looks very un-sporty when attached IMHO, but then I don't look back there too often when riding :-)
09-14-2021, 07:20 AM
Givi plates will mesh up with pretty well any good and crappy rack laid on the back of the CB1100. No over-thinking is required.
Can't imagine going anywhere long these days without a carrier and topbox.
09-14-2021, 08:04 AM
  Luggage Racks pekingduck 8 771 06-02-2026, 07:57 AM
Last Post: HondaLou
  Givi Airstar Universal Windshield - A660 peterbaron 2 627 12-28-2025, 02:15 PM
  Givi rack for top box. Nick_imp 6 579 01-17-2025, 03:55 PM
  Top box, Givi, Shad or maybe something else? Davidjill_imp 17 1,418 07-25-2024, 08:22 AM
  Hepco & Becker luggage Nitro_imp 12 1,082 03-20-2024, 03:37 AM
Last Post: Mitch_imp
  Looking for [2014] Honda luggage rack Jollygods_imp 7 895 05-09-2023, 10:30 PM
Last Post: JRM_imp
  Any soft luggage racks compatbile with Deluxe and OEM rack? slackerdeluxe_imp 3 453 09-11-2022, 04:47 AM
  Luggage oldgoat01_imp 127 9,722 05-31-2022, 05:52 AM
Last Post: LayerCake_imp
  Luggage question mach9_imp 2 363 04-17-2022, 10:23 AM
Last Post: mach9_imp
  Hard luggage suggestions? run-tmc_imp 35 2,319 03-28-2022, 09:55 AM
