Switching handlebars
ambbmw_imp Offline
Threads: 1
RE: Switching handlebars
What are going to so with the stock handlebars? I'd be interested with the bar in weights.
12-26-2017, 09:42 PM
3rdbike_imp Offline
Threads: 7
Nice warm day here, so the garage was tolerable. Got started on the h/b change. Everything went smoothly, so I'll let some pix do the talking:
[Image: 1dc8023dc257784a25c99d953a9c2279.jpg]
a plumb bob from the bar end to show the amount of pull back of stock bar.
[Image: deef4c4dbf0977aff8b31b0d7316469c.jpg]
left side controls can be split and directly removed from the bar, instead of sliding them off the end. Controls hung in place, no flopping or banging around during switch. Right side controls loose and ready to have h/b pulled out from them vs. sliding them off the end of the bar.
[Image: 8d12a984788e1e581cb49ecce0252ba5.jpg]
Look Ma, no bars!
[Image: 971eddf2263ce1be192533e2c12ec273.jpg]
pic to show difference in bend. Stock bar on top, Flanders on bottom. Not a fair representation tho. Stock bar tilts back quite a bit to bring grips down, Flanders bar will tip forward quite a bit to bring grips up. This will let me lean into the bars without losing much for height.
Hope to finish tomorrow. Hafta drill holes for the locating pin in the controls. I'm scheming on using the stock bar ends and my favorite CRG bar end mirror on the left, and a throttle lock mechanism on the right.
12-28-2017, 12:27 PM
Likes Received: 644 in 286 posts
Likes Given: 802
Good start...measure twice, drill once lol
12-28-2017, 01:38 PM
3rdbike_imp Offline
Threads: 7
Finally finished the switch tonite, but too late for a test/shakedown run. Everything turned out the way I wanted, the cables and hoses fit just fine with the new bars, no stretching or rerouting needed. I chose not to use Honda's clever internal vibration damper, but still used the stock bar ends. The Flanders bar is made of good stuff, quite heavy by itself, so we'll see how it is on the road. If my next post is really blurry, you'll know something is wrong! Now for some pix:
[Image: 475faee6e7e3b9b66cc7f9592427ae09.jpg]
Please refer to previous pic of gas tank and plumb bob. The bar change moved the grips forward a good three inches.
[Image: c3c032664c3cfcb425e264a97c5d70d0.jpg]
Want to cut a perfectly round hole in the end of a grip? Make this tool from a piece of pipe of a diameter that is a snug fit inside the grip. Use a file the sharpen the edge of the pipe a little. Insert into grip and hammer it through. Viola!
[Image: 7d0f45f53e7717aaf0a04c116f877f67.jpg]
[Image: 7bcd2e6c24df5a607b7eaf941c87bd86.jpg]
This is my mod to use the stock bar ends w/o the rest of the vibration damper system.
[Image: d9f725bf9c722e76a7ee36adf2bf65e2.jpg]
That 'step-down' in diameter on the bar end will not fit into the bar. I made use of the space for a bar-end CRG mirror on the left, and my "50cent cruise control" on the right which uses O-rings to create enough friction to hold the throttle open but not so much that I can't turn the throttle easily. Again, more Harley habit.
[Image: f6ba8c86fcd9fdb6e5b4f870f14c9124.jpg]
The finished product from the saddle. Bar is narrow at the center, just a 1/2" to spare at the clamps.
[Image: c778c00b868dcc7925d6dd1c9e8a596c.jpg]
left side and bar end mirror.
[Image: 3c86ad07dc58eec8c7e801ffffc21466.jpg]
front view
[Image: 7077229e8a11843210465654612f6f82.jpg]
from the side. This shows the forward tip of the bar the best, and the drop at the grips. May not be everyone's cup of tea, but my wrists are happy!!
12-31-2017, 04:21 PM
Likes Given: 802
Cool. That's certainly a different look. As long as you are happy. Here's hoping the test ride and subsequent rides prove you made the right choice.
Reminds me a lot of Brit bikes late 60's early 70's
01-01-2018, 12:02 AM
Likes Received: 890 in 486 posts
Likes Given: 1,024
It is a different look. I'll be interested to hear how you find it. But, if it solves your discomfort, it will be well worth it.
01-01-2018, 08:00 AM
3rdbike_imp Offline
Threads: 7
A short test ride today was very satisfying. I had 'nailed' the positioning of the bar, levers, switch housings and mirror during assembly. Now the CB feels like my bike. I have my ol' Guzzi T3 set up with the same bars which work very well for me, so I was confident in my choice of the same bar for the CB. Yes Ferret, this bar was popular on the Brit bikes for decades. The 'bend' has been around for a long time.
It puts me in that classic 'European' riding position. The CB's pegs are positioned perfectly under me, I ride on the balls of my feet (for corner clearance) and with this bar, I lean forward into the wind. It's a balanced riding position: weight distributed between feet, butt, arms and chest and the wind. Wind noise in the helmet is less. I can crouch down out of strong winds comfortably with the grips still out ahead of me. Because of the drop and angle, I sometimes think of this bar as 'tall' clip-ons.
I've ridden many a long mile on my ol' T3 with my brother-in-law, he rides a Harley dresser, and can't understand how I can stand to ride a motorcycle with just a "banana seat" and no windshield! Undecided
Oh, I nearly forgot....again! I was half way into my test ride today before I remembered to check for vibration in the bar/grips. There wasn't any. I think the set-up will be fine. But then I used to ride a 441 Victor, and a Sportster.
No "skinny" posts from me, Ferret!
01-01-2018, 10:54 AM
PowerDubs_imp Offline
Threads: 125
(01-01-2018, 12:02 AM)The ferret_imp Wrote: Cool. That's certainly a different look. As long as you are happy. Here's hoping the test ride and subsequent rides prove you made the right choice.
Just saw the picture of the bars installed. First thought was looks like an old Schwinn bicycle. Big Grin
04-25-2018, 11:38 PM
  Taller Handlebars DBM_imp 7 775 03-27-2022, 03:42 AM
  handlebars Crossfire_imp 2 351 03-15-2022, 11:29 PM
  Wider handlebars, Tracker style. JLEECB 18 1,944 05-16-2021, 09:31 PM
Last Post: Zee9_imp
  09 CB900 Hornet handlebars ozigoo 6 586 07-24-2020, 04:03 AM
Last Post: max
  CB1100RS handlebars cooky6660_imp 25 1,710 11-26-2019, 05:58 AM
  Narrower Handlebars pekingduck 4 533 10-08-2018, 03:43 PM
  Type 2 Handlebars Installed Capo 4 488 09-21-2018, 07:02 AM
  In search of those elusive handlebars. FLYTYM_imp 8 709 07-06-2018, 03:03 AM
Last Post: 3rdbike_imp
  New more comfortable handlebars geosar_imp 27 2,126 05-22-2018, 05:47 PM
  Who also installed these clubman handlebars from Dime City Cycles? chync_imp 4 443 03-25-2018, 08:11 AM
Last Post: chync_imp
