Smart Turn System
RE: Smart Turn System
The Smart Turn System offering seems appealing, and by 21st century (2019) availability, should not be profound. The old early '80's Yamaha self-cancelling offering was good, but I would say maybe about 90%+ reliable. Therefore, the rider is still checking the cancel anyway. But that was almost 40 years ago and it was likely very primitive, electro-mechanical in nature and limited to one or two degrees of sensitivity. I speculate the ST2 offering is a full-embedded solution with multiple degrees of sensitivity and sensor signal analysis to get closer to 100% reliability. I suppose ultimately, would a rider get to the level of comfort to not confirm the signal cancel? I reckon for many, that habit is burned into our riding check ritual.
04-27-2019, 10:51 PM
Obleo Offline
Threads: 16
Yes we have been down this path before. I have a 2004 Road King Custom that has self canceling turn signals,always work never a problem. May need to say that Honda could catch up to old tractor technologies. May be should start another thread to up my post count . Hello and welcome to the forum.
04-27-2019, 10:55 PM
17-CB-002 Offline
Threads: 45
Hi GO,
Can you please describe/explain how the Yamaha "Self Cancelling" works?
06-04-2019, 12:47 PM
(06-04-2019, 12:47 PM)Alain Lee_imp Wrote: Hi GO,
Hey Alain:
I didn't tear one down. I just used them as a rider.
Given the era in which they worked, I suspected they were quite primitive. I don't mean mercury switch primitive, but possibly a voltage source detection primitive. There might be some online information.
I recall when the rider asserts a turn signal, the engine rev speed was either high (moving and possibly decelerating) or stopped and lower engine rev. In the first case the system voltage is high - maybe 13.5V. When stopped idling at a light the system voltage might be 12.4V. When the rider accelerates again, the engine speed increases and the system voltage transitions back up to 13.5V. Maybe a "capacitor-based timer" begins following the transition of low-to-higher voltage and when it completes, it kills the signal relay using a switching transistor.
Assuming this was somewhat the approach (and I really don't know), the problem was when the rider signaled during a constant velocity turn keeping a decent engine speed. In this case, the signals would often not cancel automatically (which I experienced) because the elevated system voltage was maintained. In addition, I also recall sitting stopped at turns with signals flashing and revving the throttle a few joyful times. That would also sometimes cancel the signals.
I don't recall auto signal cancelling during lane changes at speed working well either.
Of course today, this can all be nicely done in a lightweight digital embedded system and likely a reasonably organized state machine design around some reliable sensors.
06-04-2019, 01:28 PM
Ernie_imp Offline
Threads: 1
Yes . I have the neutron activated protein powered signal turn off installed at birth.
06-11-2019, 07:44 PM
(06-11-2019, 07:44 PM)Ernie_imp Wrote: Yes . I have the neutron activated protein powered signal turn off installed at birth.
lol - Welcome back to the Forum Ernie!
06-11-2019, 09:36 PM
Rocky_imp Offline
Threads: 26
I must check to see if I have one of those ROFL ROFL ROFL
06-11-2019, 10:34 PM
Obleo Offline
Threads: 16
Yes, indeed welcome to our humble forum .
06-11-2019, 10:41 PM
http://cb1100forum.com/forum/showthread....#pid256277
12-20-2019, 01:00 AM
(12-22-2019, 12:21 AM)m in sc_imp Wrote: the self cancelling signals on yamahas worked off a sensor in the speedometer actually. there was a pickup that senses over a certain speed it would then trigger a relay and 'kick' the switch off in the control. My rz had one as did some RD400s and XS650s that ive seen. just fyi.
Yes, I would say over the decades Yamaha probably had the most reliable implementation of all the brands. It wasn't 100%, but I would say at least 90% reliable on a healthy, well-looked after bike.
I think Honda's implementation is significantly more technical in nature. Who knows? Maybe it is over-engineered like a German electrical brake light system? I suppose 2020 AT owners will determine in time.
12-22-2019, 12:28 AM
  Exhaust system/slip-on johnny_elpino_imp 26 2,424 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 4,254 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,996 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  DLX Exhaust System Conversion Ron in MO_imp 28 2,237 08-26-2021, 10:50 AM
Last Post: bvictory_imp
  hepco becker side back C system alexzanutto_imp 16 1,699 07-31-2021, 07:34 AM
  Smart Turn System ozigoo 6 663 05-30-2021, 10:59 AM
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 2,017 01-25-2021, 08:39 AM
  FOBO tire pressure monitoring system report.. Chuckk_imp 120 8,709 11-28-2020, 10:38 AM
Last Post: Chuckk_imp
  Arrow full system exhaust tsmetjen_imp 19 1,591 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
  Delkevic full system?? juliang_imp 4 488 07-29-2020, 05:50 AM
Last Post: Bheezy27403_imp
