HANDLEBAR RISERS - is really necessary???
PowerDubs_imp Offline
Threads: 125
RE: HANDLEBAR RISERS - is really necessary???
I put on bars that are wider and have more pull back. Same height as stock. More relaxed.
Pics here- http://cb1100forum.com/forum/showthread....#pid283091
12-13-2020, 04:02 AM
redbirds_imp Offline
Threads: 186
I'm short at 5' 6" but found the stock bar height perfect. Like has been said, right is what works for you.
12-13-2020, 04:25 AM
peterbaron Offline
Likes Given: 1,013
(12-13-2020, 04:25 AM)redbirds_imp Wrote: I'm short at 5' 6" but found the stock bar height perfect. Like has been said, right is what works for you.
^^+1^^
12-13-2020, 05:22 AM
Alfgaxatico_imp Offline
Threads: 17
RE: HANDLEBAR RISERS - es realmente necesario???
friends ; today I removed the handlebar risers; and as I thought; my arms are rather long; I'm 1.85; and more control of the weight of the CB1100 EX europe 2015; since it falls as it should fall: ahead. apart it is illegal in Spain to lift the handlebar (if they see it). there will be cases that improves comfort; but in my case not ... the effect that I noticed; it was as if the front wheel was with more air than normal ... but hey; each one feels it in a way.
12-16-2020, 07:39 AM
tod.branko_imp Offline
Threads: 19
(12-16-2020, 07:39 AM)Alfgaxatico_imp Wrote: friends ; today I removed the handlebar risers; and as I thought; my arms are rather long; I'm 1.85; and more control of the weight of the CB1100 EX europe 2015; since it falls as it should fall: ahead. apart it is illegal in Spain to lift the handlebar (if they see it). there will be cases that improves comfort; but in my case not ... the effect that I noticed; it was as if the front wheel was with more air than normal ... but hey; each one feels it in a way.
Now we know why Harley Davidson sells poorly in Europe lol
I'm happy that you feel more comfortable Alf
'14 CB1100 STD 5 speed
12-16-2020, 02:21 PM
jtopiso_imp Offline
Threads: 13
As far as I know, it's legal to raise the handlebar, or change it's longitudinal position. What you can't do is to use a wider handlebar, unless you get it inspected and certified.
In my case (short arms), pull-back raisers have improved confort a lot. Although the bike looks much better without them.
12-16-2020, 05:43 PM
Threads: 19
In my case (short arms), pull-back raisers have improved confort a lot. Although the bike looks much better without them. [Image: 64c86db41ffddffae6a2b90a2416f8b5.png] gosh the rules, the bureaucrats just won't leave people alone
12-16-2020, 06:04 PM
Threads: 17
Ok my friend . In Spain ITV ; in the bi-annual govern review, they consider a change of direction importance; (many BMW TRAILs place it for comfort); but the control of the front end; even more so if you have a companion it is more precise with the original configuration. But if comfort improves; worth taking ...
12-16-2020, 06:45 PM
jtopiso_imp Offline
Threads: 13
(12-16-2020, 06:45 PM)Alfgaxatico_imp Wrote: Ok my friend . In Spain ITV ; in the bi-annual govern review, they consider a change of direction importance; (many BMW TRAILs place it for comfort); but the control of the front end; even more so if you have a companion it is more precise with the original configuration. But if comfort improves; worth taking ...
Good to know Smile When the time comes, I might remove my raisers before getting the bike inspected.
12-16-2020, 08:00 PM
In my case (short arms), pull-back raisers have improved confort a lot. Although the bike looks much better without them. [Image: df431e69093c7f3cfd833534f2ba5a34.png] gosh the rules, the bureaucrats just won't leave people alone
Dodgy Yeah, so much minutia, hard to believe it is enforceable, unless there is a Nazi traffic officer with too much time on their hands.
12-16-2020, 10:40 PM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 3,003 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 334 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,789 08-07-2025, 05:24 AM
  VOIGT Risers Duderino_imp 3 468 11-23-2024, 01:09 AM
Last Post: Obleo
  Handlebar Risers?? bubblerboy64_imp 16 1,591 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 776 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 558 04-03-2022, 01:00 AM
  ROX Risers and longer brake line? MrBob_imp 3 475 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Rizoma risers on the cb1100 Zee9_imp 20 1,680 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  Handlebar from 919 motorider6_imp 10 975 05-27-2021, 12:47 PM
Last Post: Stichill
