Honda top case install
iamlegend21087_imp Offline
Threads: 15
RE: Honda top case install
(12-30-2021, 10:05 PM)Jonnyteabag_imp Wrote: Sure no problem.
What do you want specifically? Are you wanting to match a key from another bike to your old case? I ask as you probably know you can buy the genuine honda lock kits to do this.
The instructions for doing this are freely available from the honda accessory portal http://cssportal.css-club.net/honda/MCA/MAIN010.aspx
This gives a good idea on how things fit together.
You'll need to follow the links for the VFR 800F which uses the 33ltr top case we are talking about here.
I will post up some pics as soon as I can get to the bike but let me know what you want.
Regards,
JT
Actually I mean the mechanism that actually clips the top case to the mounting plate. Mine is not attached to the top case and I'm trying to figure out what screws are used.
12-31-2021, 03:55 AM
Jonnyteabag_imp Offline
Threads: 18
The Honda top case mount is mounted in two parts, the sturdy metal base plate is solidly bolted to a flat plate of your choice, I chose the hepco backer rack as it came with side arms and a small top plate, I figured that if the HB plate was too small to mount the Honda steel plate I could just substitute a larger plate of my own.
So when the steel Honda plate is bolted on, the top plastic plate is sandwiched onto the bottom using the spacers and rubber bushings that then allow the top plate to float sideways about 10mm left and right.
This then leaves a gap between the plastic top frame and the steel bottom, the lugs of the top case engage between the two and when locked down hold the case super firmly against some rubber grommets.
The design allows the case to "float" sideways a little...this is supposed to reduce turbulence of the wind pulling at the case and sending movement thru the rack to the frame...This seems to work as I don't notice any wobbles at motorway speeds like I used to get with the solidly mounted top cases on my other previous bikes.
I realise that the above sounds complicated but if you look at my pics from the rear end view you can see there's a gap between the two honda plates this is what is needed to engage the top case and lock it down.
Hope this helps but if you read thru the plate mounting instructions in the link I sent you can see how it all fits together..
JT
12-31-2021, 09:22 AM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 527 08-20-2025, 06:25 AM
  Crank Case Cover removal? JF Coastal_imp 47 3,250 08-04-2023, 01:26 PM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,180 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
  Windjammer ss. Install caddy425_imp 15 1,348 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,311 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,371 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Givi SR1118 Top Case Rack active1951_imp 4 500 06-28-2021, 07:08 AM
Last Post: Tom_imp
  Apache 4800 top box. (HF/Pelican case) mvk24_imp 12 1,015 04-16-2021, 04:01 AM
  Givi Side Case Racks...Do they exist? cbolling_imp 21 1,271 08-28-2020, 08:34 PM
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 660 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
