auto tune 02 sensor
outback_imp Offline
Threads: 4
RE: auto tune 02 sensor
(12-10-2021, 07:27 AM)PowerDubs_imp Wrote: Outback- lets put it this way- these bikes ran hot enough (and lean enough) from the factory that they had issues during the design phase with part failure...that's why our spark plugs ended up with their own little cooling fins as example.
Even a 100% stock bike would run better - and cooler- with a power commander, even without the autotune.
If you already have the power commander and autotune- might as well use them. Having a bung welded on is chump change in comparison.
When I did on my Arrow header- I left the standard smaller bung- just in case anyone wanted to use it in the future, just put in a cap, and put the larger bung next to it so I have both options going forward.
On my new 4-4 I just had 2 large bungs put in custom- as I also bought a 2 channel autotune box that I will install so I can tune the left 2 cylinders separate from the right 2.
Thanks PD for your help, and explanations, Ill be having my buddy weld in the bung for the auto tune. Just need to get a cheap little laptop to use it and save the adjustments.
12-11-2021, 01:34 AM
outback_imp Offline
Threads: 4
Interesting, According to dynojet i should keep the stock 02 sensor in the system.
Post: #27RE: full delkevic exhaust
Thought this might be interesting to you guys, Ive been doing a lot of reading about the stock 02 sensor and what to do with it when changing exhaust ect. I decided to ask the guys at dynojet and see what they recomend. I told them the year of the bike, and the modifications i made , ect. This is what they told me
Danny Boardman (Dynojet)
Jan 14, 2022, 10:37 AM PST
Greetings gary, thank you for your inquiry. We appreciate your interest and support for our products.
For the modern bikes with closed loop systems we have found in recent testing and analysis that most modern engines now have actually been designed to run at the leaner factory settings. In the closed loop area of the fuel curve we find they generally run better if the factory closed loop system is retained and not changed. That area is generally very low engine load conditions at the low rpm and throttle, so it does not require substantial fuel changes to run optimally like the high rpm, high throttle settings do. Due to this and ever tighter emissions regulations at the state and federal levels we now recommend the factory closed loop O2 sensor components be left connected, and if using our Auto Tune it would only make adjustments outside that area where they are truly needed for the high engine load conditions at higher rpm and throttle settings. Leaving the factory sensors in place and installing the Auto tune for fuel adjustments outside the closed loop area actually gives you the best overall compromise between fuel economy and power and performance when actually needed. You get maximum economy in the low rpm throttle range, and max power and performance in the high rpm, throttle range.
Powersports Technical Support
Dynojet Research, Inc.
Free: (800)992-4993
01-14-2022, 09:14 AM
Likes Given: 750
Good info.
01-14-2022, 09:55 AM
PowerDubs_imp Offline
Threads: 125
auto tune 02 sensor
Note he said for emissions / fuel economy. (compromises)
Remember the EPA is really cracking down on tuning shops- so they aren’t going to go on record saying to remove / bypass factory sensors.
We already know on THESE bikes that low rpm low throttle is twitchy with the factory sensor fueling. They run / ride better with the sensor bypassed even on an otherwise 100% stock bike. That is a fact- not an opinion.
01-14-2022, 12:57 PM
outback_imp Offline
Threads: 4
(01-14-2022, 12:57 PM)PowerDubs_imp Wrote: Note he said for emissions / fuel economy. (compromises)
Thanks PD, Yes i did note those things and after all my reading and learning i'me still going use the 02 delete plug.
01-14-2022, 08:50 PM
Houtman_imp Offline
Threads: 115
[quote='PowerDubs' pid='312570' dateline='1642215428']
I do agree with the above statement from my experience with my 2013 and 2104 with the O2 sensor bypassed .
01-14-2022, 10:13 PM
outback_imp Offline
Threads: 4
ok guys, Getting nice outside. I picked up a laptop and loaded up the dynojet program software and fuel map for the 2014 w/yoshi slip on, So i can run the auto tune. I figured that map was best as its the only one thats the same year bike.
Couple Question , After running the bike for a session do you need to keep the ignition on to save the trims?
Also ive read some say not to save the trims every time you ride it for a session and some say aprox. 30 minute rides and save trims every time?
I figured since some of you guys have expierance with the auto tune you might have a few tips or helpful ideas.
Thanks Guys
03-16-2022, 04:46 AM
Threads: 125
It's up to you-
Keep in mind you may not hit every RPM at every throttle position in a short ride.
And before you apply the changes look at the map and IF there is anything odd- take it out.
Then ride again.
If you think about how many time per second 4-5-6-7-8 THOUSAND RPM is- and then realize each combustion event is crammed into a pipe for the sensor to read...it takes many rides and adaptations to get it to where you want it to be.
I'd say a good 15-20 min ride at least- and try to vary your rpm and throttle position, even if that means riding in unnatural ways to achieve it.
The further from stock your bike- the more it matters.
You want to try to hit all possibilities- low, mid, high RPM at all throttle positions and load.
Just try to avoid quick throttle chop / cuts.
03-16-2022, 06:13 AM
outback_imp Offline
Threads: 4
thanks pd
03-16-2022, 07:48 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,032 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Ghul Tune for ECU Doug Shepard_imp 21 1,670 02-22-2024, 02:14 PM
  PCV with full exhaust worth getting tune?? gretle_2.0 4 440 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Guhl Tune/Derestriction Rox_imp 84 5,538 04-10-2021, 07:23 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 555 07-18-2020, 04:14 AM
  Where to tap speed sensor signal? egleaves_imp 93 4,803 10-19-2018, 08:49 AM
  anyone tried power commander with the auto tune sensor? scott will_imp 9 719 04-28-2018, 03:46 AM
  Re-tune/flash necessary with full exhaust upgrade? Rebel73_imp 11 944 04-09-2015, 06:28 AM
Last Post: CB4ME_imp
  Webike Japan - auto USD conversion, free shipping? Guth_imp 3 358 06-02-2013, 07:30 AM
Last Post: M3-SRT8_imp
