anyone tried power commander with the auto tune sensor?
scott will_imp Offline
Threads: 9
i have swapped the fact exhaust for a moto gp headers no cat with small muffler ,, not much baffling.
i like the sound and performance of the system. after 4000 rpm the acceleration is very responsive, up till the 4000 it has a sort off lag or wind up. and i do like the snap crackle pop on deceleration from the pipe but im sure the mixture is off now im wondering if anyone has tried the power commander with autotune sensor and if it would make a big enough improvement.
the thread about flashing the ecu had me interested as well but sounds untested so far.
im not real concerned with defeating the speed limiter, im more concerned in getting there fast and getting the most out of her.
03-26-2014, 03:58 AM
Deanohh_imp Offline
Threads: 5
RE: anyone tried power commander with the auto tune sensor?
Ran it on a 09 fz1.... Worked great.
does your pipe have a 18mm thread for the wide band o2 sensor? The stock one is 12mm and the auto tune sensor was too big for my stock pipe.
03-26-2014, 04:20 AM
Threads: 9
the stock sensor screwed right into my aftermarket header
(03-26-2014, 04:20 AM)Deanohh_imp Wrote: Ran it on a 09 fz1.... Worked great.
03-26-2014, 06:12 AM
Deanohh_imp Offline
Threads: 5
The auto tune sensor won't fit.....bigger than the stock size.
03-26-2014, 06:33 AM
lola_imp Offline
Threads: 18
(03-26-2014, 06:12 AM)scott will_imp Wrote: the stock sensor screwed right into my aftermarket header
Scott, the motogpwerks comes with the 12mm O2 adapter bung for our stock O2 sensor so unscrew that and you will have the 18mm O2 bung underenath it, its Pretty neat setup.
03-26-2014, 07:27 AM
Threads: 9
thx Lola
i was thinking that and was gonna check tonite
03-26-2014, 08:04 AM
Threads: 9
Thanks to all for the help with this. That gas line getting the tank off was bugger. But the Pcv and auto tuner are in.
The auto tuner changes -20% +20% after every ride. If I'm doing it right you have to accept the adjustments for them to be added to the map. I've had 5 rides yesterday. Most change I saw on ride was 12%. The popping on decel is gone and bike runs well.
Am gonna ride more today. Power commander had told me 8 rides should have the map dialed in.
Anyone have exp w the auto tuner?
Also considering denohs custom intake.
03-30-2014, 12:46 AM
Deanohh_imp Offline
Threads: 5
In the software you can change the % of trim that the auto tune will do during your ride. After a few trim accepts, at least on my old fz1, I reduced the 20% down to 5% because when holding a constant highway speed, it seemed to be "searching" too much and every few miles would skip a beat as if it were mometarily too lean. The 5% trim limit stopped that from happening.
03-30-2014, 01:09 AM
rmack_imp Offline
Threads: 6
Scott will I ran the pcv with out the auto tuner first then fitted the auto tuner depending on what else you have done I found the results very pleasing It did take a few kms to sort itself out but now very happy with the resuls
03-30-2014, 07:30 PM
PowerDubs_imp Offline
Threads: 125
I know this is a really old post, and the OP hasn't been logged in for years- but I just wanted to say that his feeling of bog at <4k could simply be because of velocity loss in the exhaust.
The main pipe off the collector on that header looks huge in that picture. Like enough to support a car engine's flow. I'm going to go google to see if I can find out the size since I am curious, but I'd guess it is 2 inch..
04-28-2018, 03:46 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,147 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Ghul Tune for ECU Doug Shepard_imp 21 1,838 02-22-2024, 02:14 PM
  PCV with full exhaust worth getting tune?? gretle_2.0 4 452 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 869 05-15-2022, 11:42 AM
  Usb-c cable direct to battery or switched power capz65_imp 5 546 04-16-2022, 02:26 PM
  auto tune 02 sensor outback_imp 18 1,396 03-16-2022, 07:48 AM
Last Post: outback_imp
  Power Distribution Module (PDM) - Europe/UK Tev62 5 540 11-16-2021, 07:49 PM
Last Post: j3gq_imp
  Guhl Tune/Derestriction Rox_imp 84 6,573 04-10-2021, 07:23 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 577 07-18-2020, 04:14 AM
  Power Port for 2014 CB1100A (Deluxe) MWV1500_imp 5 469 12-06-2019, 09:00 AM
