Guhl Tune/Derestriction
Rox_imp Offline
Threads: 3
Im considering getting it done. Who here has it? How you like it? How's the performance? What's your top speed?
02-11-2021, 01:26 PM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
RE: Guhl Tune/Derestriction
(02-11-2021, 01:26 PM)Rox_imp Wrote: Im considering getting it done. Who here has it? How you like it? How's the performance? What's your top speed?
I gots it, Took the retardation out of the ignition timing, removed speed limiter, raised rev limiter.
I do feel is was generally a "Smoother" ride before the tune. But not a complaint. It changed my "Sweet Spot" for cruising and I dont know exactly where my top speed is but its beyond the speedo.. I did have an issue with the bike not wanting to maintain cruising speed around 70MPH after the flash. The revs were jerky. I should have just sent it back to guhls to have it adjusted but my mechanic talked me into the power commander and new fuel map and it fixed the problem.
02-11-2021, 01:49 PM
teamvisegrip_imp Offline
Threads: 4
I did a few mods that required the tune and yes it was done by Guhl. Wonderful people to work with. Bike runs amazing. It was derestricted and upped the max rpm too.
Big change with all the mods.
02-12-2021, 10:06 AM
E11even_Hunnit Offline
California
Threads: 5
Likes Given: 34
Got it.
Bike pulls better, runs smoother, and goes faster
I did experience instability at idle shortly after install(would bounce a hew hundred RPM's) but the bike has never done this again
For what it is, I do think the flash could be cheaper. But as some say, "gotta pay to play"
All said and done I'm a happy camper and have not looked back since
02-14-2021, 04:00 AM
Rox_imp Offline
Threads: 3
(02-14-2021, 04:00 AM)E11even_Hunnit_imp Wrote: Got it.
Sent it out the other day. It'll be great to have this pull like an 1100.. I guess I'll keep the Bazzaz on it to help with idle and and fueling turbulance. Thanks for the push.
02-27-2021, 12:36 PM
California
Threads: 5
Likes Given: 34
You will not be disappointed Thumbs Up
Please share your first impressions
02-28-2021, 03:21 AM
shahyaan_imp Offline
Threads: 3
You guys are lucky you have this option in the states. Still trying to find out the best option here in the UK.
02-28-2021, 07:08 AM
Likes Given: 1,010
shahyaan, I could well be wrong, but no UK member of this forum has ever posted a local or even European solution. I think one member—beardyweirdy—sent his ECM to Guhl in the US. He had no problem as far as I recall. You may have to do the same.
02-28-2021, 07:10 AM
PowerDubs_imp Offline
Threads: 125
Beardyweirdy had a real nice bike.
02-28-2021, 08:07 AM
Likes Given: 1,010
He did a lovely job on it, didn't he? Wonder what happened to it?
02-28-2021, 09:23 AM
  Ghul Tune for ECU Doug Shepard_imp 21 1,823 02-22-2024, 02:14 PM
  PCV with full exhaust worth getting tune?? gretle_2.0 4 452 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  auto tune 02 sensor outback_imp 18 1,393 03-16-2022, 07:48 AM
Last Post: outback_imp
  Don Guhl No Longer Tuning Motorcycle ECUs tj_gee_imp 45 2,994 03-08-2022, 02:48 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 575 07-18-2020, 04:14 AM
  anyone tried power commander with the auto tune sensor? scott will_imp 9 728 04-28-2018, 03:46 AM
  ECU on its way to Guhl's! Rebel73_imp 48 3,037 06-26-2016, 11:37 PM
  Re-tune/flash necessary with full exhaust upgrade? Rebel73_imp 11 982 04-09-2015, 06:28 AM
Last Post: CB4ME_imp
