Re-tune/flash necessary with full exhaust upgrade?
Rebel73_imp Offline
Threads: 79
I've got my eye on the Moriwaki black 4-2 exhaust. Does the bike need to be re-tuned?
I mean, I intend to do the Guhl flash anyway, but I want to do that AFTER so I don't have to flash all over again.
04-07-2015, 09:13 AM
Olyrider Offline
PNW
Threads: 23
RE: Re-tune/flash necessary with full exhaust upgrade?
I installed the full Yosh system last week. Worried about the same thing. Bike actually runs much better! But I am still doing the re-flash. And before that, the K & N filter. And...since Guhl doesn't have any maps for a 2013 Standard with the mods I have made, I am having my PC V dyno-tuned to get more low-end grunt. Guhl is wonderful, but he can't map a bike that he doesn't have. He can, though, change the factory settings to the RPM settings Honda gave bikes in other countries.
04-07-2015, 09:32 AM
Inline4_imp Offline
Threads: 23
You know, I was worried about the same issues as you. I recently upgraded from a Yoshimura RS3 slip-on canister to a full Nojima 4-into-1 exhaust.
The bike had no issues with the Yoshi performance-wise, BUT I found it ran a tad rich. I could stick my finger in the exhaust outlet on the Yoshi and there was always a little black soot there. No biggie but I knew it wasn't quite right.
Since I've added the full Nojima, the bike runs crisper and cleaner..........
I have about 700 miles since the change and no soot what so ever...
Even though the exhaust note is a bit more subtle with the Nojima, the bike absolutely SCREAMS when you push it to the mid/upper rpm range, especially under load.
I do want to get a PCV or whatever its called and perhaps a reflash if needed just to get optimum horsepower from the engine, but as she is right now, I couldn't be happier nor could I smile any wider when I run it hard through the gears.
04-07-2015, 12:55 PM
Rebel73_imp Offline
Threads: 79
Thanks for your feedback, guys. Good to know.
04-07-2015, 02:47 PM
Yeahoo Whoyah_imp Offline
Threads: 0
"BUT I found it ran a tad rich"
That's counter to what I'd expect, seems like it would run lean after installing aftermarket exhaust. Huh
04-07-2015, 09:40 PM
Siggy Javotnik_imp Offline
Threads: 2
(04-07-2015, 09:40 PM)Yeahoo Whoyah_imp Wrote: "BUT I found it ran a tad rich"
I had the same thought -- freeing up the exhaust would be expected to lead to a possible lean condition. However, as a fellow Yosh pipe owner, I don't think the can makes a huge difference to the air-fuel ratio. I like the Yosh because it SOUNDS so sweet -- not obnoxious, but just...right.
04-07-2015, 10:16 PM
HikerToo_imp Offline
Threads: 114
Maybe without the Cat, it allows more unburnt fuel through, therefore the illusion it is running richer......maybe just more un-burnt fuel makes it out?
04-07-2015, 10:42 PM
Threads: 2
(04-07-2015, 10:42 PM)HikerToo_imp Wrote: Maybe without the Cat, it allows more unburnt fuel through, therefore the illusion it is running richer......maybe just more un-burnt fuel makes it out?
Not a bad idea -- but the Yosh slip-on he had / I have leaves the cat intact. OTOH, if he in fact had a rich condition (which would have been unrelated to the Yosh can), removing the cat and installing a full aftermarket exhaust would lean things out a bit and could fix it. But...a stock CB1100 runs lean for emissions purposes. I used to have black carbon deposits on my exhaust if I had been taking short trips or short shifting on my '75 KE125 -- maybe that explains the carbon build-up on his Yosh?
04-07-2015, 11:52 PM
Inline4_imp Offline
Threads: 23
No short trips or short-shifting here!
Yea, I've been baffled (sorry, bad pun Big Grin ) by this too.
I have no idea why the CB seemed to be running rich with the canister. It just goes against natural thinking. Like I said, I had no issues with the Yoshi performance-wise, although I never put it on a dyno. Loved the sound, even more so than I do with the Nojima at least until I run it hard through the gears. Biker
04-08-2015, 12:25 AM
Threads: 2
(04-08-2015, 12:25 AM)Inline4_imp Wrote: No short trips or short-shifting here!
Ha!!!
04-08-2015, 01:02 AM
  '17 Grabrail Upgrade for '14 HigginsNYC_imp 26 1,807 08-15-2026, 04:11 AM
Last Post: fabrimtb
  swing arm upgrade rtmoto1 8 509 03-09-2026, 09:31 AM
  Rear Suspension upgrade 17-CB-002 3 357 02-22-2026, 09:41 AM
Last Post: 17-CB-002
  ECU Flash rev limiter etc PowerDubs_imp 34 4,331 07-06-2025, 01:05 AM
  2017 Fork Spring Upgrade deuce17EX 2 495 04-15-2025, 01:37 PM
Last Post: deuce17EX
  Speedometer Upgrade!? DirkDiggler_imp 12 1,288 02-23-2025, 04:57 PM
Last Post: Jurlie_imp
  Ghul Tune for ECU Doug Shepard_imp 21 1,881 02-22-2024, 02:14 PM
  LED Headlight Upgrade Peddlin' Slow_imp 67 5,712 02-07-2024, 09:59 AM
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,899 11-29-2022, 10:38 AM
Last Post: mrded_imp
  PCV with full exhaust worth getting tune?? gretle_2.0 4 468 05-24-2022, 03:43 AM
Last Post: gretle_2.0
