 Rubber Feet for Center Stand?
(04-08-2021, 09:48 AM)Billie_imp Wrote:
(04-05-2021, 10:43 PM)KiowaEagle_imp Wrote: After getting used to putting a goldwing on a center stand when I do it with the CB the darn thing skids back a couple of feet! I like that carpet idea or maybe even a rubber mat.
Your CB moves back 2' when you put it on the center stand?
Come on Man.
Come on Man.
Have you seen some of the high-tech epoxy-coated garage floors people have? You can eat off them. Add a little cheetah patterned foot-warming mini-carpet under the CB and things could slide pretty far, but hopefully not into the bed.
I had three 650 Yamaha twins that you could turn around on a hard concrete floor just by starting them up, and pushing on the seat as they danced on their center stands from vibration.
I tried putting rubber adhesive pads and vice pads on center stand feet on a bike years ago, but they came right off. If you think about the action the center stand feet take as they touch the ground and rotate under as the bike comes up, there’s a lot of load coming from different directions on a small area, and a pad would probably not be able to deal with it.
I have a generic rubber car floor mat that I put on the ground under my stand. My garage floor is pretty smooth and I have had issues with sliding trying to get the bike off of the stand as well. The rubber mat helps quite a bit.
Come on Man.
Come on Man.
Thank you Ferrett .
Come on Man.
Come on Man.
You get used to pulling a 900+ pound bike up on a center stand doing it with the CB is like a feather. That plus a slick concrete floor....
2 ft may be a stretch but it can slide back a lot.
I don't think my CB moves an inch on or off the center stand- that I use pretty much everywhere and every time I park it.
I don't have a problem putting my bike ON the center stand, I have a problem taking it OFF! I have a very slippery garage floor, and I always use my center stand. Many times I end up pushing my bike several feet forward with the stand sliding across the floor without folding up until there is no more room to go when attempting to take it OFF the stand. Then I have to drag it back by pulling on the luggage rack and try it all over again. I will purchase a cheap carpet with a rubber bottom to place below it.
Come on Man.
Come on Man.
What happened to my Biden reference?
Come on Man.
Come on Man.
Come on Man.
It was moderated due to several complaints. We don't do political here.
Come on Man.
Come on Man.
Come on Man.
Come on Man.
It was moderated due to several complaints. We don't do political here. You were right on this one Ferret !
  What does G91 stand for under the gastank cap (see pic)? bioman_imp 8 671 07-06-2022, 02:01 AM
Last Post: bioman_imp
  Need help ! Center stand installation enterlance_imp 14 1,014 01-08-2022, 05:25 AM
  Attaching center stand Whippa_imp 9 790 12-18-2020, 06:15 AM
Last Post: Rocky_imp
  Rubber dampers for the 2017 CB1100 EX's front rotors VLJ_imp 14 1,533 06-21-2019, 11:56 PM
Last Post: 17-CB-002
  Warm feet Randy B 18 1,634 11-10-2018, 11:23 AM
  Has anyone removed the rubber from their stock footpads? DoyleInMN_imp 6 416 04-26-2015, 01:31 AM
  Shifter Question. Big Feet holy666diver_imp 5 503 04-11-2015, 10:06 AM
Last Post: aschem_imp
  Side Stand Pivot emptysea 10 656 01-24-2015, 01:51 PM
Last Post: gossman_imp
  With a Center Stand do you even need a front stand? PJV_imp 16 1,117 10-31-2013, 09:44 PM
Last Post: sanoke_imp
  Abba Stand Work on the CB PJV_imp 0 197 10-25-2013, 09:36 AM
Last Post: PJV_imp
