 Rubber Feet for Center Stand?
Does the center stand have any optional rubber feet? Mine is bare metal, and it slides around on the pavement. Even if I lift it gently onto the stand, it still seems to slide a couple of inches before it comes to rest.
Not that I have ever come across. It’s probably been done before on some obscure make or other. Most things have been done haven’t they. I stick a piece of old carpet under mine in the place I park it in the garage, that works fine.
I have never considered rubber booties. All my bikes had the usual steel feet slide (many times anyway) on the mounted surface.
They may exist, but I have never seen a bike with rubber feet.
I have no problem at all using the center stand on my fairly smooth concrete garage floor (the only place I use the center stand) so it's not something I ever thought about.
I had the same problem , being a concrete contractor / builder my garage floors are super smooth. When taking the bike off the center stand it would just slide. Solved the issue with a horse stall mat 4’x6’ x 3/4 thick rubber . It also prevents flat spotting on the tires. It’s cost was $ 70.00
After getting used to putting a goldwing on a center stand when I do it with the CB the darn thing skids back a couple of feet! I like that carpet idea or maybe even a rubber mat.
Sometimes I'll use some thin plywood - if surface damage might be an issue.
These guys have a 20% off sale every year, next one around I'll pick up one of these Bike mats. There must be something similar over there.
https://www.motorcycleshop.ie/biketek-ga...7512-p.asp
(04-06-2021, 12:24 AM)Tev62_imp Wrote: These guys have a 20% off sale every year, next one around I'll pick up one of these Bike mats. There must be something similar over there.
Neat.
Since I don't have a garage, the baby rug won't be needed. Big Grin
(04-05-2021, 10:43 PM)KiowaEagle_imp Wrote: After getting used to putting a goldwing on a center stand when I do it with the CB the darn thing skids back a couple of feet! I like that carpet idea or maybe even a rubber mat.
Your CB moves back 2' when you put it on the center stand?
Come on Man.
  What does G91 stand for under the gastank cap (see pic)? bioman_imp 8 669 07-06-2022, 02:01 AM
Last Post: bioman_imp
  Need help ! Center stand installation enterlance_imp 14 1,011 01-08-2022, 05:25 AM
  Attaching center stand Whippa_imp 9 785 12-18-2020, 06:15 AM
Last Post: Rocky_imp
  Rubber dampers for the 2017 CB1100 EX's front rotors VLJ_imp 14 1,522 06-21-2019, 11:56 PM
Last Post: 17-CB-002
  Warm feet Randy B 18 1,631 11-10-2018, 11:23 AM
  Has anyone removed the rubber from their stock footpads? DoyleInMN_imp 6 413 04-26-2015, 01:31 AM
  Shifter Question. Big Feet holy666diver_imp 5 501 04-11-2015, 10:06 AM
Last Post: aschem_imp
  Side Stand Pivot emptysea 10 653 01-24-2015, 01:51 PM
Last Post: gossman_imp
  With a Center Stand do you even need a front stand? PJV_imp 16 1,101 10-31-2013, 09:44 PM
Last Post: sanoke_imp
  Abba Stand Work on the CB PJV_imp 0 194 10-25-2013, 09:36 AM
Last Post: PJV_imp
