Heated Grips End Caps
(12-19-2013, 08:27 AM)GaryRudolph_imp Wrote: They are about the same hardness/design as the stock.
Bleh. And they're unbelievably expensive. ~$350 for the two kits required. Gack. I may end up buying them anyway. :-D
Hello, where do you plug in the heated grips ? Is there an accessory outlet ? If so, what type of plug it connector is it ? Can you post a pic ?
I'm have my heated jacket installed directly to the battery and would like to install it to a switched outlet so I don't drain the battery if I forget to switch off the accessory
Thanks
Sent from my iPhone using [url=http://tapatalk.com/m?id=1]Tapatalk
They have a module that connects inline. It's not something that is easily usable for a heated jacket. I think you're better finding a switched source and wiring in a relay.
(01-12-2014, 01:10 PM)IndianRider_imp Wrote: Hello, where do you plug in the heated grips ? Is there an accessory outlet ? If so, what type of plug it connector is it ? Can you post a pic ?
Thanks
There's a complete wiring harness for the grips that connects to the bike's wiring; it's not something you could really hook anything else up to.
Don't you have to disconnect from the bike to get off of it? How could you forget that?
  spark plug caps alexzanutto_imp 3 417 01-29-2023, 06:21 AM
Last Post: artashline_imp
   Heated Grips on the EX michael1954 25 1,953 01-21-2021, 04:24 PM
Last Post: michael1954
  Heated grips removal Chris potato_imp 7 473 07-26-2018, 11:27 PM
Last Post: itstuantran_imp
  Would love some input on the install of the factory heated grips. Tim_imp 2 343 05-06-2018, 03:08 AM
Last Post: Tim_imp
  OEM Heated Grips Tim_imp 12 736 04-25-2018, 05:20 AM
  Heated Grips; Honda OEM vs. Aftermarket cookiemech 10 764 01-20-2018, 09:03 AM
  Wiring heated grips adventureAF_imp 6 616 11-21-2017, 01:03 PM
Last Post: adventureAF_imp
  Taking Off Handlebar Grips Toddman_imp 7 487 05-24-2017, 03:21 AM
Last Post: Toddman_imp
  2017 CB1100 RS - Heated grips cable sleeve hdvalente_imp 2 267 05-21-2017, 07:17 AM
Last Post: hdvalente_imp
  Torque values for replacing Front fork top caps please IndianRider_imp 17 1,074 03-20-2017, 01:27 PM
Last Post: IndianRider_imp
