JIS screw drivers
(04-29-2014, 12:43 PM)Ridem32_imp Wrote: Thumper: people that have never used the JIS screwdrivers just don't know how good they are! Just look around at the jap bikes with striped screw heads.
Michael
I'm as guilty as the rest--I didn't discover JIS screwdrivers until about 2 years ago!
Please, if you have a Japanese motorcycle, and do any sort of work removing fasteners on your bike, please put a set of JIS screwdrivers in your toolbox.
Like Michael said, once you put a JIS tool to your Japanese fasteners, you'll understand what you've been missing.
Cheers all! Beer
Ordered a set today. Never knew!
I own a #2 and #3 size JIS and find that that's all I need to do all the services on my Japanese bikes.
I'm jizzing over the JIS screwdrivers. Sadly they're hellishly expensive over here! Undecided
And not very readily available to boot!
I wonder if the two-piece screwdriver in the plastic tool pouch in the tool compartment under my seat has a JIS tip, and if so, which number?
Self-answer: appears to be JIS, yes. But still not sure what size it is.
The hex wrench is 5mm, which fits the side cover fasteners, the fasteners holding on the front fender and front brake-line stays and some of the bolts in the front calipers, though I'm sure the shortness of the supplied hex wrench would prevent it being useful for anything except removing the side covers.
Yes, the screwdriver in the kit is JIS.
Amazon has a decent set for $40: http://www.amazon.com/Hozan-JIS-5-JIS-Sc...003F63WI8/
Size 00, 0, 1, and 2, as well as an extra long 2 (good for removing the screws that hold my seat down on the CBR).
The screwdriver in the tool kit does not have a good handle to grip for tight screws. But on the road better than nothing lol. I have several pairs of honda motor pliers from the 60, s when the tool pouch had tools in it. Smile
Here is another good set from amazon. Personally the yard stick one I will pass on. Okay maybe not yard sick size but that one was pretty long.
This set is $27.10!
http://www.amazon.com/gp/aw/d/B00A7WAHTU...L500_SS115
[Image: 4512b0abde044fcbc81e4d3d58170e37.jpg]
Sent from my XT1055 using Tapatalk
I have been fighting with the screws on carb tops and bowls for 40 years when jetting my japanese bikes, never knew the screws were not phillips.Once I finally got them out I replaced them with little tiny allen screws.Like the ferret says DANG! Huh
Thanks
  Sight Glass Screw Mickey Dublin_imp 16 1,394 11-22-2023, 08:25 AM
  Brake reservoir screw head issue satchit 72 4,455 04-24-2022, 11:55 PM
  Dealing with a stuck JIS screw Stichill_imp 28 2,069 06-27-2021, 10:21 AM
Last Post: Stichill_imp
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,205 04-15-2020, 01:53 AM
  Speedometer Allen Head screw loose mhicks17_imp 1 231 09-15-2018, 02:55 PM
Last Post: max
  JIS Screw Drivers & Screw Driver Bits 2017EX_imp 8 669 06-04-2018, 12:22 PM
   Beam adjustment screw :) Riko_imp 13 978 06-11-2017, 10:50 PM
Last Post: White Dog_imp
  screw in front tire Krupator_imp 25 1,341 06-20-2016, 11:10 AM
Last Post: pw363_imp
  Crankshaft Balancer backlash adjustment screw tomas_imp 12 815 05-17-2016, 07:28 AM
Last Post: furious_blue_imp
  Idle screw? Jayimpalaman_imp 12 884 05-05-2015, 04:34 AM
Last Post: 1953andrejrigoli_imp
