12-27-2014, 11:41 PM
Mix a little dish soap in some water then put a few drops on the valve stem and see if that's where it's leaking. Might be able to fix it by just replacing the valve core or putting on a good steel cap on.
Slow leak and valve stem relacement?
12-28-2014, 02:02 AM
(12-27-2014, 11:41 PM)sanoke_imp Wrote: Mix a little dish soap in some water then put a few drops on the valve stem and see if that's where it's leaking. Might be able to fix it by just replacing the valve core or putting on a good steel cap on. Found this to be the case far more often than the valve stem body being bad. |
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 678 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| Valve Adjustment and Camshaft Removal | dave | 5 | 618 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 855 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Cover Baffle lining ? | bflint | 6 | 922 |
07-26-2025, 11:27 AM Last Post: bflint |
| Slight Oil Leak | DutchRutter | 22 | 3,898 |
05-16-2025, 06:49 AM Last Post: peterbaron |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,819 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,479 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
| Oil Leak? | bvictory_imp | 0 | 212 |
06-14-2023, 07:05 AM Last Post: bvictory_imp |
| Observed Valve Clearance | Cormanus | 16 | 1,406 |
03-06-2023, 09:03 AM Last Post: Tejas_imp |
| The OBSERVED Valve Clearance thread | Pterodactyl_imp | 162 | 12,309 |
12-27-2022, 08:35 AM Last Post: Cormanus |
