04-26-2014, 04:55 AM
Look at the outlet of the pipe. Its not a round hole like on the US bikes.
Interactive exhaust valve
04-26-2014, 05:13 AM
Oh I've seen that. that's it? Where are the cables and servo motor that controls it?
04-26-2014, 05:28 AM
(04-26-2014, 05:13 AM)The ferret_imp Wrote: Oh I've seen that. that's it? Where are the cables and servo motor that controls it? if you look at your air intake duct, there is a rubber cap that is glued in. For the valve control there would be a hose leading to some kind of diaphragm down by the passenger foot rest which actuated the gizmo in the exhaust can. No motor or cables. Either I saw that someplace or dreamed it...forget which.
04-26-2014, 10:36 AM
Used to tune the exhaust so high revving whacko sport bikes (which typically have it, like my buddies GXR) can have some torque at lower rpms. Back pressure can be a good thing for a motor, low down rpm's for in town riding is one place for it.
04-26-2014, 10:56 AM
(04-26-2014, 05:28 AM)Deanohh_imp Wrote:(04-26-2014, 05:13 AM)The ferret_imp Wrote: Oh I've seen that. that's it? Where are the cables and servo motor that controls it? if you look at your air intake duct, there is a rubber cap that is glued in. For the valve control there would be a hose leading to some kind of diaphragm down by the passenger foot rest which actuated the gizmo in the exhaust can. No motor or cables. Either I saw that someplace or dreamed it...forget which. The valve: [/img] The actuator cable: [/img] Cheers
04-26-2014, 10:59 AM
how about that! very interesting. thanks Pterodactyl
04-26-2014, 01:12 PM
(04-26-2014, 10:56 AM)Pterodactyl_imp Wrote:(04-26-2014, 05:28 AM)Deanohh_imp Wrote:(04-26-2014, 05:13 AM)The ferret_imp Wrote: Oh I've seen that. that's it? Where are the cables and servo motor that controls it? if you look at your air intake duct, there is a rubber cap that is glued in. For the valve control there would be a hose leading to some kind of diaphragm down by the passenger foot rest which actuated the gizmo in the exhaust can. No motor or cables. Either I saw that someplace or dreamed it...forget which. The valve: [/img] The actuator cable: [/img] Cheers Thanks for the photos Pterodactyl, do you have a Staintune unit on your machine.
04-26-2014, 06:12 PM
Tyke57nz, G'day.
Yes, I fitted the Staintune last week. Staintune advise, in the fitting notes, that the actuator cable should be removed from the bike along with the OEM exhaust. The Staitune itself is not fitted with a valve. I haven't had it on the road yet as I am off riding for a short while. It may be another 3 - 6 weeks before I get out on the road. Upon firing the bike up, in the shed, I was impressed by the sound effects. As most members on this forum have reported, not "hoon" loud but a clear, deeper note, just about what I was looking for. Staintune do claim a performance increase. This is immaterial to me, I can scare myself with the neddies that are already available. From what I gather, being at the best a "bush mechanic", the ECU receives no input regarding valve operation. In any case I may fit a PCV. When I am back on the road I will try to meet with VicsCB1100, who was the OP in the Smooth Power Everwhere thread, before coming to a PCV decision. The subject has probably been done to death but any other member input would be appreciated. Cheers.
04-26-2014, 08:52 PM
(04-26-2014, 06:12 PM)Pterodactyl_imp Wrote: Tyke57nz, G'day.Thanks for that info, I had the side cover off and figured that it would be a case of removing the lower servo and hose from the upper servo unit on the side of the airbox and fitting a blanking cap. Good to hear that the noise is somewhat improved, did you run with the baffle in or out? Cheers
04-26-2014, 09:50 PM
(04-26-2014, 08:52 PM)Tyke57nz_imp Wrote:Thanks for that info, I had the side cover off and figured that it would be a case of removing the lower servo and hose from the upper servo unit on the side of the airbox and fitting a blanking cap. Good to hear that the noise is somewhat improved, did you run with the baffle in or out? Cheers(04-26-2014, 06:12 PM)Pterodactyl_imp Wrote: Tyke57nz, G'day.Thanks for that info, I had the side cover off and figured that it would be a case of removing the lower servo and hose from the upper servo unit on the side of the airbox and fitting a blanking cap. Good to hear that the noise is somewhat improved, did you run with the baffle in or out? Cheers No worries. I left the other (upper) components in place. The lower servo will still be active but, with the actuator cable removed, to no effect. Unless the Gurus on this forum (come on Red Mist et al) convince me otherwise, then thats how it will stay. All baffles in the Staintune remain in place. I don't believe that the CB muffler has a removable sound restrictor. Cheers |
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 693 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| Valve Adjustment and Camshaft Removal | dave | 5 | 624 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 860 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Cover Baffle lining ? | bflint | 6 | 931 |
07-26-2025, 11:27 AM Last Post: bflint |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,858 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,483 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
| Observed Valve Clearance | Cormanus | 16 | 1,428 |
03-06-2023, 09:03 AM Last Post: Tejas_imp |
| The OBSERVED Valve Clearance thread | Pterodactyl_imp | 162 | 12,461 |
12-27-2022, 08:35 AM Last Post: Cormanus |
| Checking valve clearances | Maturecheese_imp | 74 | 6,460 |
12-11-2022, 12:56 PM Last Post: GoldOxide_imp |
| Valve noise (i think) | Maturecheese_imp | 6 | 633 |
07-08-2022, 03:41 AM Last Post: 1973cb750 |
