Rear Tire Time, 14K
That's awesome! How do you do this?
I had to change my first set of oem tires (Dunlop) after 5,000 km, which is just 3,125 miles.
I was commuting a little over 110 miles a day on the freeway.
Hmmm, I got a little over 10k from the front, 14k from the rear on my OEM Bridgestones.
5k front, 7k rear. Ridden briskly Smile
8300kms and time for a front tire. Rear looks good till about 12k. Time to try some Angel GTs. I'm hoping they will give me longer wear life.
"usually"......
longer wear, harder tire, less grip
shorter wear, softer tire, more grip
It's finding the proper combo that makes you happy
My old Ninja used to get 5K miles on rear, 7K on front. That includes the occasional burn-out :-)
(07-28-2015, 07:52 AM)HikerToo_imp Wrote: "usually"......
Then there are dual compound tires like the Michelin PR3 and Bridgestone BT45s. Harder compound in the center for better wear, softer compound on the sides for grip. I use PR3s on the CB11 and BT45s on the CB750 and they really are the best of both worlds.
Then there are dual compound tires like the Michelin PR3 and Bridgestone BT45s. Harder compound in the center for better wear, softer compound on the sides for grip. I use PR3s on the CB11 and BT45s on the CB750 and they really are the best of both worlds. How does braking figure in to the dual compound idea.....I've had less grippy tires that would lock up noticeably sooner than others while hard braking.
I haven't noticed that problem. I get regular practice making hard stops riding if Phoenix traffic every day and I've never locked them up.
  Rear only tire on the front? mattmcuomo@yahoo.com 5 579 10-09-2023, 06:05 AM
  trying to put a tire on for the first time. won't inflate? misterprofessionality 46 3,097 04-26-2019, 02:07 PM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  New Rear Tire and Rear Brake Pads memphismike_imp 5 528 06-11-2018, 09:35 PM
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 343 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  Rear tire replacement H.Ibsen_imp 13 903 10-08-2015, 12:34 PM
Last Post: H.Ibsen_imp
  Rear tire on the front gcarper_imp 13 818 11-24-2014, 12:26 PM
Last Post: Guth_imp
  Nail in rear tire. meowguy_imp 25 1,766 07-29-2014, 10:28 PM
Last Post: Elipten_imp
   Need help/advice regarding removing the rear wheel/tire p-man_imp 16 1,097 05-07-2014, 01:15 PM
  My original rear tire. Randy B 4 395 02-16-2014, 12:22 PM
Last Post: Randy B
