High revs after re-fueling.
Make sure you don't touch your throttle before starting. Start bike. Should idle fast for a few seconds, then come down as it warms up. If the idle stays high, check your throttle cables for out of adjustment and adjust per spec.
(08-06-2015, 06:23 PM)Cormanus_imp Wrote: Tried a couple of times when I was out today and noticed two things: the first was a momentary roughness the first time; the second was a slight momentary increase in revs, but not up to 3000 rpm.
Interesting. I've only done it a few times (by accident). Some days I forget which bike I'm riding. Occasionally, I turn the key on the CB750 and find myself waiting for the fuel pump sound and gauge cycle.
Both times I did it I got a high rev. I wonder if results vary depending on what point in the boot process you hit the starter?
Oh, deary me, I can see hours of fun with a stop watch ahead of me. Not.
  'Factory' high performance spark plugs PowerDubs_imp 17 1,461 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,734 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,513 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,487 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  CB1100 EX fueling & speedo Ol' RedJ_imp 7 601 07-16-2023, 02:17 AM
  High mileage and oil consumption Jurlie_imp 24 2,046 04-07-2023, 06:05 AM
  High idle mattmcuomo@yahoo.com 7 669 10-29-2022, 11:09 AM
   Dutch's High idle thread DutchRutter 17 1,489 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 3,812 07-05-2022, 11:41 AM
  Really high idle Gordo_imp 124 9,713 11-16-2021, 02:37 PM
