High revs after re-fueling.
I've noticed after I fill the tank that the engine revs high when I first start the engine. My bike has always done this and it has never been a problem and it only lasts for a couple of seconds. Has anyone had a similar problem.
Maybe not a problem. When the engine is cold the ECU schedules a higher idle RPM, amongst other things. Up around the 1600RPM mark. Maybe, in colder weather, when you refuel, the engine, or at least the point of temperature input, cools enough for this to take effect for a short period. After starting the residual heat plus the engine returning to normal operating temperature soon brings the idle speed to normal. That's my guess anyway.
Sorry, should have been more specific. It only happens when I pull into a servo and fill up. Engine is hot. Sometimes revs up to around 3000 rpm for a second or so.
Check throttle for sticking? After that I'm done.
(08-05-2015, 11:27 AM)Tezza_imp Wrote: Sorry, should have been more specific. It only happens when I pull into a servo and fill up. Engine is hot. Sometimes revs up to around 3000 rpm for a second or so.
Are you sure you waited until the computer boot was finished before hitting the starter? On my bike, if I hit the starter before the gauges have completed their startup sequence, the bike will rev up exactly as you describe.
Hey, good thinking. I always allow mine to cycle through prior to thumbing it.
I've been know to forget to allow the computer to cycle completely before starting and don't recall it revving like that. Might have to go out and try it.
Tried a couple of times when I was out today and noticed two things: the first was a momentary roughness the first time; the second was a slight momentary increase in revs, but not up to 3000 rpm.
Mmmmmm. Hey Tez, what kind of oil are you using?
Dr Dactyl's HUBRIS Omnigrade Motorcycle Oil, I believe. He's about 2,451 kms left before the bike carks it.
  'Factory' high performance spark plugs PowerDubs_imp 17 1,461 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,733 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,513 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,484 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  CB1100 EX fueling & speedo Ol' RedJ_imp 7 601 07-16-2023, 02:17 AM
  High mileage and oil consumption Jurlie_imp 24 2,046 04-07-2023, 06:05 AM
  High idle mattmcuomo@yahoo.com 7 667 10-29-2022, 11:09 AM
   Dutch's High idle thread DutchRutter 17 1,489 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 3,809 07-05-2022, 11:41 AM
  Really high idle Gordo_imp 124 9,710 11-16-2021, 02:37 PM
