Leaking Fork Seal?
There's a tool designed to clean out the seal, similar to the camera film fix. It's called Seal Mate and costs around $6-$7. If the seal isn't damaged, it actually works! Check out their video :
http://www.sealmate.net/
Fork seal replacement can be a pain in the butt, so I strongly recommend either the Seal Mate or the film trick before you tear into the forks.
I'd second buying the tool. It's specifically designed to grab under the dirt and pull it out. You can accomplish this with film (dirt sticks in the tractor feed) or a feeler, but it won't work as well or be as foolproof.
For us old cheapos if you can't scrounge up some old film negatives in your personal archives a bit of clear water bottle should work since they tend to use a really thin plastic on those flimsy things.
A soda bottle is probably too thick since it needs to hold in the carbonation.
Aloha,
Huladog
I used a piece of paper that was laminated with thin stock to slide down the tube. I passed the card 2-3 times. I pumped the forks about 10-20 times wiping them down intermediately. I rode for about 5 minutes and low and behold nothing on the forks. Unless I post back in the next 2 weeks I will consider it fixed. Thanks to all for the tip!!!!
(04-27-2016, 05:56 AM)Motogeezer1949_imp Wrote: Fork tubes can get nicked by stones causing a burr that can ruin a seal as well.
Always check, otherwise your new seal may not last very long either.
Yes. Dead insects, dried on the fork, will do the same. Just fix it. Jamming film or objects in there is just as likely to rip the seal. It just happens sometimes, like a nail in your tire. Why have oil leaking and flying all over the place, like on your brake rotor, controls, etcetera?
I saw a post on one forum, the guy was saying how his rear brake sucked and didn't work at all on his 2016 ZX-10R. No one could figure it out, he got all kinds of advice about bleeding it (bad idea with a full ABS system as he had) and such.
A few hours later the same guy posted that earlier the same day, his oil filler cap (an aftermarket piece, not safety-wired or properly tightened, apparently) had come off and spewed oil all over the right side of the bike; he post images of the tire, wheel, and appurtenances coated with nice fresh oil.
Not surprisingly, no one on the forum made the patently obvious deduction that the reason his rear brake did not work was because, perhaps, it was coated with a prodigious quantity of motor oil?
Motorcycles are machines, they are very predictable in design and behavior. The only things new about them are the digital technology and intervention systems, which can be baffling. (This is why matrices and algorithms are taught in higher-level math classes these days).
Fork seals, oil, oil filters, cams, crankshafts, wheels, tires, suspension...it all works the same as it did. Just get her fixed and be confident about the bike, it is better than worrying.
(04-27-2016, 03:28 PM)Flynrider_imp Wrote: There's a tool designed to clean out the seal, similar to the camera film fix. It's called Seal Mate and costs around $6-$7. If the seal isn't damaged, it actually works! Check out their video :
I can go along with that; if it's already leaking you don't have much to lose except the 6 bucks. Worth a try.
I've made a cleaner from plastic water bottle... cut into the shape of the cleaner you can buy.
Sent from me......
To protect my forks from bugs, dirt, nicks, etc., I installed Triumph fork deflectors; install in minutes and look professional. Part #s A9641010 (Tall Deflector) or A9641005 (Short Deflector), I went with the short ones on my CB1100.
http://www.motorcyclestore.us/triumph/ac...rotectors/
  Fork seals leaking @19,000 miles on ODO Frulk_imp 64 5,073 12-26-2023, 10:11 PM
  Oil pan leaking George050994_imp 26 2,140 08-17-2023, 09:34 PM
  fork overhaul vs. fork replacement? misterprofessionality 20 1,845 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Gas leaking from overflow tubes Edtheguy_imp 11 826 09-01-2020, 02:35 AM
  Leaking fork seals Tezza_imp 33 2,335 08-04-2020, 10:34 PM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 772 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
  need help quick - oil leaking DJS_imp 32 2,058 08-24-2016, 02:04 AM
Last Post: Riko_imp
  slowly leaking - wondering if I own a lemon CB1100 Riko_imp 10 746 06-21-2016, 03:37 AM
Last Post: Riko_imp
  Drain Plug New Oil Seal Razorbacjac_imp 31 1,852 10-30-2014, 11:47 PM
Last Post: DAC
  Fork seal leak shdwghst457_imp 42 2,794 03-27-2014, 07:23 AM
Last Post: Gingersdaddy_imp
