High Speed Front Brake Pulsation
(10-02-2015, 07:45 AM)The ferret_imp Wrote: Are you sure its the brakes? How is the front tire?
Good call, sir. My tires were embarrassingly low on air. I had noticed a fall-off in handling, and some squirly behavior and inability to hold a turn during high-speed (70+mph) sweepers. To be honest, I've gained some weight, and I thought maybe I had to re-adjust the preload. Fixed the pressure last night, rode in this morning, everything is working exactly as it should, no pulsation, set the lean and bike stays there, and no more wallowing in turns that I noticed had started. This bike appears to be very sensitive to tire pressure.
Most bikes ARE sensitive to tire pressure being off. It's the rider who does or doesn't pick up on it.
(10-05-2015, 03:15 AM)ClassicVW_imp Wrote: Most bikes ARE sensitive to tire pressure being off. It's the rider who does or doesn't pick up on it.
My CBR, with a much more sophisticated suspension, doesn't react in nearly the same way as the CB with regard to changes in tire pressure. Usually, if the tires get aired down on that bike, you jut get better grip. With the CB, it seems like unless the tires are within a few pounds of the recommended pressures, braking is affected, weird suspension stuff starts happening, etc. I dunno, I only have these two bikes for comparison.
Sorry to resurrect this zombie thread, but I believe I'm experiencing the same thing as the OP. My front tire pressure is spot-on at all times (I check prior to every ride), and the front brakes are definitely rhythmically pulsing in direct correlation with the speed of the bike, as described in the original post here. Before I run off and order a new set of front discs, can anyone comment on the possibility / advisability of just getting whatever warping exists machined out at a good brake shop? Sorry if it's a dumb question, I know that back in the day I had car brakes services that way, but I'm not sure if it's wise or even possible with these discs. No problem if I need to buy new replacements, but I was just curious about other options...thanks all!
First some specs. Front wheel runout is 0.020mm (.008in) both radial and axial.
Front disc thickness is 4.5mm +- 0.1mm (0.18 +-0.004in). Service limit 3.5mm (0.14in).
The book says to replace the disk if it is below specs on thickness.
If warped, it says to check the wheel bearings for excessive play and replace disk if bearings are normal.
Me personally--I'd put a dial indicator on the wheel and the disk and check for runout, check the wheel bearings, then replace the disk(s). They are pretty thin. Having said that, slightly resurfacing them might be ok. Hopefully someone more knowledgeable about this will chime in.
My car disks are pretty thin, and the forum for that said resurfacing doesn't work and they will warp right back, but the dealer said it does work and they have been good for a year with pulsing gone.
I also read, maybe on the forum here, that material transfer from the pads will cause pulsing. You might want to get some Scotchbrite and clean up the rotors and see if that fixes it.
Check tire pressure before every ride. Every day if necessary. Or don't but be aware based on this thread that you are asking for trouble some day. A tire can pick up an invisible puncture, like a staple, that can't be seen and only detected by noting a pressure decrease on the gage. Sometimes the bead seal is not complete, and tires will leak slowly over time, or the valve core is not tight. You get out on the freeway, that tire will overheat and perhaps fail. Hit the high-speed turns, it's just something you don't need and five minutes of your time will help make sure you don't have these issues.
Toward the high range is better for street riding, can't really go wrong with the recommended 36F/42R if you weigh more than 180 pounds.
Just communicated with Dunlop regarding track pressures and was informed that they now make these recommendations based on a 180-pound rider, not 160 as it used to be. We are getting bigger and heavier, Dunlop figured it out. Used to be 32F/30R, now they're saying 32F/32R. I can't use those numbers, no traction or temperature in the tire, I run 29F/28R but use an infrared thermometer to make sure temps are where they should be.
It IS a science and tires are a very important system on your bike, in my opinion, the MOST important as they communicate directly with the road.
I don't wash my bikes often but I check tire pressure and inspect the tires visually before every ride, every time. Chain tension gets checked weekly.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 116,730 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 838 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 515 02-13-2025, 06:25 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,462 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Front ABS Brake"Rain Stick" noise bflint 3 448 07-12-2024, 08:36 AM
Last Post: Race_ca1
  High engine revs on start up CBX1000_imp 21 1,742 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,523 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,539 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  Front brake inconsistent resistance ChiefJP_imp 16 1,332 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 921 06-14-2023, 07:34 AM
