High Speed Front Brake Pulsation
Before I get a chance to tear the front brake apart, was wondering if anyone had any ideas:
Noticed yesterday coming home the front brake pulsates at speeds > 50mph under moderate to heavy braking. Bike has only 6k miles on it. I was thinking that one of the rotors might be slightly warped, but I don't see how. I plan on taking a look at both rotors and pads when I get a chance this weekend.
Are you sure its the brakes? How is the front tire?
I had a bad set of rotors. Waranteed. They are kind of thin and get hot easily, especially in the mountains. I use both brakes a lot now rather than mostly the front to try to keep them cooler.
(10-02-2015, 09:32 AM)Motogeezer1949_imp Wrote: I had a bad set of rotors. Waranteed. They are kind of thin and get hot easily, especially in the mountains. I use both brakes a lot now rather than mostly the front to try to keep them cooler.
^this. That sounds like warped brake rotors
I had this pulsating problem (very rapid grab release, grab release) with the front brake on my Bonneville last year during braking. Braking from a high speed was machinegun like and very annoying.
I changed the rotor and it was gone.
Very strange for it to happen on a low mileage machine that has never been abused, but it did.
No such problem with the CB.
I've replaced two front brake rotors on my VFR800 over the past ten years that suddenly, and for no reason warped. My bike exhibited the same symptoms you describe. Out of curiosity, was your front tire replaced recently? The mechanic could have damaged the rotor when replacing the tire.
(10-04-2015, 05:09 AM)Dave_imp Wrote: I've replaced two front brake rotors on my VFR800 over the past ten years that suddenly, and for no reason warped. My bike exhibited the same symptoms you describe. Out of curiosity, was your front tire replaced recently? The mechanic could have damaged the rotor when replacing the tire.
No, the tire had not been changed.
While I was at it I took the opportunity to change the rotor with an EBC kit which included a new rotor and brake pads.
It much improved the braking so in a way I'm glad it happened.
They sell a dial indicator / vise grip tool for measuring rotor run-out. Maybe a parts store that lends tools has one. YouTube will show you how to use it. A micrometer is needed for thickness variation.
Might just be brake pad deposits on the rotors.
(10-04-2015, 12:37 PM)immgunn_imp Wrote: They sell a dial indicator / vise grip tool for measuring rotor run-out. Maybe a parts store that lends tools has one. YouTube will show you how to use it. A micrometer is needed for thickness variation.
A runout check is good advice. A basic check, to see if there is any runout, can be done by clamping a wire, or other object, in touch with the rotor and then rotating the wheel. Any significant runout can be then observed by eye. To measure that runout you will need a dial indicator. A reasonable quality dial indicator is not expensive. Runout limits are described in the service manual. I don't have my manual by my side but will post the runout limit if you need.
Cheers.
Minimum rotor thickness is 3mm. I measured mine last week.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 116,722 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 837 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 515 02-13-2025, 06:25 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,462 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Front ABS Brake"Rain Stick" noise bflint 3 448 07-12-2024, 08:36 AM
Last Post: Race_ca1
  High engine revs on start up CBX1000_imp 21 1,742 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,522 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,539 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  Front brake inconsistent resistance ChiefJP_imp 16 1,332 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 921 06-14-2023, 07:34 AM
