Cylinder head cover discoloration
If that is the clear coat that darkened, then you can remove it and respray.
Mine still looks new. As mentioned above, both of those covers are removable, so you could just get the powder in the original silver if you so desired.
Just looked at mine. Silver also like rest of cyl head cover.
I have seen gasoline stain chrome finish like that. Check for leaks from your tank or fuel lines
Sent from my SM-G935V using Tapatalk
I noticed last time I had the cam cover off the engine that there was 4 small o ring type seals that appear to be part of the secondary air supply system. Only one of them had remained in the head and the other 3 had dropped down into the fins on the cylinder head. There doesn't appear to be a mention of them in the shop manual. If your cam cover has been removed at some stage they may have fallen out allowing exhaust gas to enter the area where the discoloration is.
Those o rings are on the parts diagram though.
  Clutch slave cylinder gasket Maturecheese_imp 3 400 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  Brake reservoir screw head issue satchit 72 5,437 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,751 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Cams, Compression, Head Work? boynton6spd_imp 12 992 08-08-2021, 02:27 AM
Last Post: old blue_imp
  CB900 Custom oil stopper on valve head AOrhun_imp 9 835 01-27-2021, 10:06 PM
  1 cylinder running rich? frank_imp 33 2,247 01-05-2021, 10:35 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 769 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 659 09-01-2020, 12:19 AM
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,392 04-15-2020, 01:53 AM
  Key Cylinder Spins Freely deltamark 16 1,180 10-28-2019, 11:06 AM
Last Post: Chuckk_imp
