Cylinder head cover discoloration
Have you guys come across this before? This cover has turned a nice copper color. I haven't seen this condition on any other CB's. I'm guessing it's heat-related but the bike runs great. Bike has about 12k miles.
[url=http://s1285.photobucket.com/user/ericlevy/media/Mobile%20Uploads/197AEEC8-1256-405B-B31D-7F74E2F86847_zps34mw0lwf.jpg.html][Image: c84f91a20a5a5e7df3b20c32428a0dee.jpg]
Mine still look like new. How does your other one look?
That cover has a different coating than the valve cover, is all.
Huh, I thought that was all one piece, but according to this diagram, that is a reed valve cover that screws on to the cam cover.
http://www.partzilla.com/parts/search/Ho...parts.html
Have you tried some polish on it to see if that returns it to the original color?
Covers are for the PAIR valves.
On my bike, 2013 standard non-ABS, that little PAIR valve cover is painted a silver metallic and has not yellowed at all. I do believe some changes were made in 2014 to finish items and other details.
Thanks everyone. I've not bothered trying to polish it out, and the one on the other side is fine. Just looking to the forum collective to see if it's unique to my bike.
Kind of like a 'birth-mark'??? Confused
(08-22-2016, 12:31 AM)LongRanger_imp Wrote: Thanks everyone. I've not bothered trying to polish it out, and the one on the other side is fine. Just looking to the forum collective to see if it's unique to my bike.
I don't think that you could polish it out anyway as it likely has a clear coat over the polished/anodized aluminum. You'd have to take it down to bare metal and then it might darken later anyway.
I was just wondering if those Reed Valve covers had ever been removed on your bike such as during a valve adjustment/inspection. If the reed valve was not replaced properly or was leaking, it may be possible for hot exaust gasses to travel the wrong way and heat up the cover.
I was just wondering if those Reed Valve covers had ever been removed on your bike such as during a valve adjustment/inspection. If the reed valve was not replaced properly or was leaking, it may be possible for hot exaust gasses to travel the wrong way and heat up the cover. Yes to all the above.
  Clutch slave cylinder gasket Maturecheese_imp 3 401 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  Brake reservoir screw head issue satchit 72 5,562 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,808 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Cams, Compression, Head Work? boynton6spd_imp 12 1,006 08-08-2021, 02:27 AM
Last Post: old blue_imp
  CB900 Custom oil stopper on valve head AOrhun_imp 9 844 01-27-2021, 10:06 PM
  1 cylinder running rich? frank_imp 33 2,328 01-05-2021, 10:35 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 776 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 663 09-01-2020, 12:19 AM
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,433 04-15-2020, 01:53 AM
  Key Cylinder Spins Freely deltamark 16 1,213 10-28-2019, 11:06 AM
Last Post: Chuckk_imp
