Low fuel indicator...Can't see miles remaining!
(09-26-2016, 07:20 PM)curlyjoe_imp Wrote: You could try disconnecting/reconnecting the battery. I disconnected the battery on my ST to reroute the battery tender and my trip A/B and average MPG "reset".
I'll try it!...So I should simply disconnect the battery and immediately reconnect it?
I'll try it...So I should simply disconnect the battery and immediately reconnect it?
Wouldn't hurt to just let it sit for a minute or 5 to let any capacitors discharge. Then reconnect it.
Update: Thanks CurlyJoe and others...I disconnected and reconnected the battery and its working again. I can't be certain that was what fixed it or perhaps it fixed itself as some have suggested. Regardless, I'm happy its working again.
Much like your home and laptop computers...if something's not 'right', often it's necessary to just power-down and restart - clears the 'cobwebs' (caches & temporary files) out and starts from scratch.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,537 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 693 04-18-2024, 03:01 AM
  Power source for oil indicator led norton1974_imp 1 283 12-31-2022, 10:07 AM
  Gear indicator Billie_imp 11 985 02-22-2022, 03:24 AM
Last Post: gswanson89_imp
  Service indicator - unleashed j3gq_imp 6 638 07-27-2021, 03:12 AM
  Rear indicator design problem Mixagon_imp 5 516 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Turn Indicator Switch question Scotty_imp 6 519 09-22-2020, 11:58 AM
  Gear shift indicator stuck on 4 bflint 39 2,736 03-11-2020, 02:46 AM
  Changing indicator lamps max 1 213 12-02-2018, 07:47 AM
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,990 08-03-2018, 12:35 AM
Last Post: apex1_imp
