Low fuel indicator...Can't see miles remaining!
After getting a 4000 mile oil change I noticed when running low on fuel I get the flashing indicator but not the count down from 45 is there a way to reset this?
Glen, some members have had this happen. Read this and the following posts to maybe fix it: http://cb1100forum.com/forum/showthread....#pid134775
I can't help much more as I have a '13 and it doesn't have the miles to go feature.
My 14 STD sometimes will not show miles left, only flashing. It will sometimes switch back and forth while I am riding. Doesn't bother me much, where I ride there are plenty of gas stations.
(09-25-2016, 04:53 AM)Carguy1959_imp Wrote: My 14 STD sometimes will not show miles left, only flashing. It will sometimes switch back and forth while I am riding. Doesn't bother me much, where I ride there are plenty of gas stations.
It's not so much that it bothers me. I think what bothers me is the fact that it had been working and it no longer is. Any way, worst things can happen.
Seems odd to me. Is there anything in the manual about being able to turn it on and off?
(09-25-2016, 11:49 AM)Cormanus_imp Wrote: Seems odd to me. Is there anything in the manual about being able to turn it on and off?
No, not that I could find.
Is it supposed to start counting down at 45 miles to go? Mine started at 61 miles when the last bar began flashing yesterday.
It doesn't surprise me that its different for different people. On the ST1300, the miles to go is based on fuel consumption of the last 20 miles (or 20 minutes, I can't remember offhand).
I would imagine the CB is the same. If you speed up, you will get less miles than indicated and get more if you slow down. But it is not totally accurate.
(09-26-2016, 09:20 AM)BestStandard_imp Wrote: Is it supposed to start counting down at 45 miles to go? Mine started at 61 miles when the last bar began flashing yesterday.
Mine does too.
You could try disconnecting/reconnecting the battery. I disconnected the battery on my ST to reroute the battery tender and my trip A/B and average MPG "reset".
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,539 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 695 04-18-2024, 03:01 AM
  Power source for oil indicator led norton1974_imp 1 283 12-31-2022, 10:07 AM
  Gear indicator Billie_imp 11 985 02-22-2022, 03:24 AM
Last Post: gswanson89_imp
  Service indicator - unleashed j3gq_imp 6 639 07-27-2021, 03:12 AM
  Rear indicator design problem Mixagon_imp 5 516 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Turn Indicator Switch question Scotty_imp 6 520 09-22-2020, 11:58 AM
  Gear shift indicator stuck on 4 bflint 39 2,738 03-11-2020, 02:46 AM
  Changing indicator lamps max 1 213 12-02-2018, 07:47 AM
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,990 08-03-2018, 12:35 AM
Last Post: apex1_imp
