Honda oil filter cut open
Goes to show you that Honda Engineers do know what they are doing. I even use OEM oil with that in mind. There. I said it.
Thanks for the effort to cut 'er open and share the pics, not to mention your insight into the construction based on your years of experience. Wix is a quality brand, so it's nice to learn the Honda filter is up to snuff with it and in some ways better.
Great stuff!
I use Wix or NAPA (NAPA filters are Wix filters) in most of my stuff. never had an issue. If any of you guys have aftermarket filters I'd be happy to cut then open and post pics if you wish to send them to me. Just my 2 cents, I just don't see any reason to not use the OEM filter. That said not my engine and not my wallet.
Thanks for cutting one open. Nice to know the results. Having said that, I wonder about how we overthink this. Don't know to have ever heard of an engine failing from a poorly designed oil filter. (Maybe improperly installed - hmmm seems there's another thread about that here somewhere.)
Don't forget the K&Ns blowing their top. Pretty scary (and dangerous) stuff.
(12-14-2016, 11:22 AM)DAC_imp Wrote: Thanks for cutting one open. Nice to know the results. Having said that, I wonder about how we overthink this. Don't know to have ever heard of an engine failing from a poorly designed oil filter. (Maybe improperly installed - hmmm seems there's another thread about that here somewhere.)
DAC, check this thread http://cb1100forum.com/forum/showthread.php?tid=9576
Thanks for the reminder. Sheesh, read that a while ago. Spaced out. Sticking with Purolator here.
Decades ago a brother had a Kmart oil filter blow it's can off the base and lost all the oil and the engine. It was a Vega so no great loss. I always use quality filters and oil since then. Worth the money.
Oh Riceburner, you had one of the finest cars that General Motors produced: The Vega, the Chevette the Oldsmobile V-8 diesels (a diesel head bolted to a gas block with blown head gaskets), etc. I don't have bragging rights since I was driving a Ford Maverick. Thankfully I had (and still have) a Honda CB77 Superhawk with a rear rack to run to a auto parts store and get parts to repair the Maverick! The good old daysExclamation
The Honda filters are made in the USA by Toyo Roki to a very high spec. These are easily one of the best OEM filters I've seen -- even the steel in the case material looks higher quality than most other filters.
@DAC. You can get non-catastrofic failures too: reduced engine life from things like ineffective anti-drainback valves giving you semi-dry starts after sitting, poorly designed filter media or end caps that don't seal and effectively give you reduced filtration, or crappy bypass springs that let the filter run in bypass all the time...
  Oil Filter dave 12 550 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,483 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,524 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,897 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,568 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,478 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 911 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,208 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,923 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,392 09-07-2021, 07:44 AM
