Wiring an aftermarket Lucas tail light
I found out the hard way about British electrics on my 500 Triumph. The spark plug coils were under the tank mounted with cheap alloy brackets. One of the brackets broke and the coil touched the tank. That threw the timing off and seized the pistons. I was 370 miles from home in Laconia, NH at the time. That Turnip was the only motorcycle I ever owned that left me stranded.
I owned two BSA Lightnings and they never gave me a problem.
I had a Lightning 650. Great bike, too small for me but fast and handled. Engine was a peach too and reliable. Much underrated bike i think...
I had a BSA 750 triple. No problems with electrics while I owned it, but keeping oil INSIDE the cases was an excercise in frustration. Every pair of levis I owned had a permanantly stained left shin.
(02-07-2017, 12:50 PM)The ferret_imp Wrote: I had a BSA 750 triple. No problems with electrics while I owned it, but keeping oil INSIDE the cases was an excercise in frustration. Every pair of levis I owned had a permanantly stained left shin.
I don't about the triples, but the Lightning had a built in chain oiler that nobody knew about. Inside the primary chain case was a small pocket. A channel at the bottom of the pocket led to a small rubber hose above the drive chain. The primary chain was bathed in oil. As it spun it threw oil in the pocket that dripped down onto the drive chain, and it threw oil all over the place.
When I rebuilt the motors of my two Lightnings, I dropped a bead of solder into the bottom of the pocket to seal it closed. No more greasy side down.
The chain was simple lubricated with motor oil from a small oil can. When the engine oil was changed, the chain was removed and boiled in it. It was then hung on the clothes line with a coat hanger to let the excess run off. Today's tree huggers would faint if they knew what we did with the motor oil after that. Rolleyes
  2017 tail light rattle Venteuri_imp 2 399 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  Wiring Lighting ymtnpoah11_imp 9 868 02-24-2023, 08:49 AM
  looking for extended hoses & wiring Griz53_imp 0 212 01-24-2023, 09:43 AM
Last Post: Griz53_imp
  2017 Tail light housing swap dogclerk_imp 0 211 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 777 05-01-2022, 06:23 AM
  Tail light install problem iamheero_imp 9 747 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Looking for wiring schematic HondaFan_imp 2 355 04-10-2021, 08:54 AM
  Aftermarket clocks Still.Cruzin_imp 10 795 01-29-2021, 06:11 AM
  LED tail light connector shahyaan_imp 10 952 11-28-2020, 09:33 PM
Last Post: shahyaan_imp
  2017 EX Tail light wire channel access TXBikerGuy 8 802 07-26-2020, 06:57 AM
Last Post: TXBikerGuy
