Wiring Lighting
Best practices for wiring when replacing lighting?
I have a damaged tail light and turn signal ready to replace. It appears there are no connectors at these ends.
I suppose I can solder the signal connection, but what about the tail light?
One thread I found discussed removing the fender and accessing the wiring harness under the battery box. Is there a better way?
Thanks!
(02-21-2023, 05:30 AM)ymtnpoah11_imp Wrote: Best practices for wiring when replacing lighting?
Thanks!
could you please describe model, type of light (led?), and damage
because it depends
2014 Black (USA)
I'm replacing oe lights with oe lights
The entire chrome housings
(02-21-2023, 11:57 AM)ymtnpoah11_imp Wrote: 2014 Black (USA)
There absolutely is a connector under the fender. It's a short pigtail with the light socket on it. #2 in the image.
https://www.hondapartshouse.com/oemparts.../taillight
In real life the pigtail goes to a boot under the seat on the left side of the space the battery is in.
(02-22-2023, 04:23 AM)Lord Popgun_imp Wrote: In real life the pigtail goes to a boot under the seat on the left side of the space the battery is in.
Ah, thank you LPG. I haven't messed with the tail light at all, but the pigtail didn't look long enough in the picture to reach that far.
Randy, the fiche for the rear turn signals shows the same short leads, but they actually go to that boot too. Are longer than the drawing looks.
Okay. So the connections are near the battery. Then one way to replace oe lights would be to remove the fender and de-route and re-route the wiring harnesses as they are.
But... is there an easier way? (that's still durable/sound)
I imagine someone has replaced lighting and done it differently.
No need to remove the fender.
ymtnpoah11, I don’t think it’s all that difficult. Take the seat off and you can easily access the wiring.
  looking for extended hoses & wiring Griz53_imp 0 204 01-24-2023, 09:43 AM
Last Post: Griz53_imp
  Looking for wiring schematic HondaFan_imp 2 324 04-10-2021, 08:54 AM
  2017 EX high beam wiring question TXBikerGuy 5 476 07-24-2020, 09:58 AM
  A maze with no exit (brake light wiring) misterprofessionality 35 2,290 04-06-2020, 11:06 AM
  wiring diagram cb1100 max 9 1,013 08-28-2019, 12:15 PM
  Wiring diagram for turn signals. kmoney_imp 21 1,282 05-06-2019, 03:42 AM
Last Post: domeular_imp
  CB1100 Wiring Cormanus 13 1,032 09-06-2018, 10:26 PM
  Samurai Tail Light wiring HWdesign_imp 8 626 08-04-2018, 01:25 AM
Last Post: HWdesign_imp
  left control wiring caddy425_imp 2 302 03-26-2018, 12:42 PM
Last Post: caddy425_imp
  Wiring heated grips adventureAF_imp 6 596 11-21-2017, 01:03 PM
Last Post: adventureAF_imp
