LED tail light connector
Hiya
I want to change up the rear of the bike and am looking at a new LED rail light. I however either need a bullet connector to OEM harness or the connector itself so that I can make the connection direct to the OEM harness. Any suggestions?
[Image: 139db038b6e231e9088e4388e67e98c3.jpg]
This is the connector in question
I get connectors here: http://www.cycleterminal.com/hm-sealed-series-090.html
If you don’t see the one you need, ask them.
Revzilla has some premade that can maybe be used.
(11-27-2020, 01:52 AM)Lord Popgun_imp Wrote: I get connectors here: http://www.cycleterminal.com/hm-sealed-series-090.html
That’s perfect thanks. I’ll measure the connector and hopefully it’s the right one. Can’t be too difficult can it?
That particular connector is hard to find, as it has 3 wires crimped to terminals in a very narrow connector. I have seen similar sized in some front turn signals of different brands, but you likely will have to cut the stock taillight wires.
At least you can buy the stock wire and bulb socket if needed.
I cut off the OEM connector from the tail light and then connected it to the LED taillight wires with bullet connectors.
Yes, I know I might want to use the OEM headlight at some point in future, but I'll cross that bridge when I get there
'14 CB1100 STD 5 speed
(11-27-2020, 03:36 AM)pekingduck_imp Wrote: That particular connector is hard to find, as it has 3 wires crimped to terminals in a very narrow connector. I have seen similar sized in some front turn signals of different brands, but you likely will have to cut the stock taillight wires.
I wanted to avoid cutting in case I want to revert back. Trying not to mod too much. Also it’s the LED unit on the RS unfortunately it’s the whole unit.
(11-27-2020, 04:24 PM)tod.branko_imp Wrote: I cut off the OEM connector from the tail light and then connected it to the LED taillight wires with bullet connectors.
Just trying to avoid cutting. But I can’t see those connectors here in the UK. Cutting may have to be the way or will see if I can get a second had tail light.
[/quote]
[/quote]
If you bought the 2014 taillight socket and wire, you could cut it instead of your LED light.
This guy might be able to sort you out. He would be quite well referenced in the Africa Twin forums.
https://www.easternbeaver.com/Main/Elec_...ctors.html
(11-27-2020, 06:05 PM)Tev62_imp Wrote: This guy might be able to sort you out. He would be quite well referenced in the Africa Twin forums.
I’ll check this out as well. I need to get to the connector to grab some measurements. The picture above was from online.
Do the connectors sit behind the side covers?
No. The are in a boot that is located in the battery compartment. Remove the tool box and look behind the battery on the left side. It hangs by the vertical frame rail. The red accessory connector is in there too. Kind of a pain to mess with.
  2017 tail light rattle Venteuri_imp 2 374 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  Headlight shell acc connector HBFL_imp 2 333 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  2017 Tail light housing swap dogclerk_imp 0 197 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 707 05-01-2022, 06:23 AM
  Tail light install problem iamheero_imp 9 702 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  obd connector andyoz_imp 12 973 07-12-2021, 09:59 AM
  2017 EX Tail light wire channel access TXBikerGuy 8 741 07-26-2020, 06:57 AM
Last Post: TXBikerGuy
  Tail Tidy and Plate Relocation jethrofelix_imp 21 1,678 06-05-2020, 12:03 PM
Last Post: run-tmc_imp
  running light and brake light Ennsync_imp 3 405 01-02-2019, 11:24 PM
  Samurai Tail Light wiring HWdesign_imp 8 631 08-04-2018, 01:25 AM
Last Post: HWdesign_imp
