CB1100 2017 - How to have turn signal always on
Jmac, you have to ask MrBi0, I have a '13. I'm just trying to help MrB with his new '17.
(03-13-2017, 11:05 AM)Lord Popgun_imp Wrote: Yes. The front signals are always on. They blink when you select left or right turn signals or emergency flasher.
I took a quick look at the wiring diagram and all that is controlled by the Turn Signal-Position Relay. It has two 4 pin connectors
The bulbs are connected to chassis ground on one side and the other goes directly to the relay. Switch inputs also go there to tell it to flash the signals or blink all the lights if the emergency flasher is selected.
It MAY be as easy as swapping in a TurnSignal-Position Relay from a US model, or a European model that has front signals on all the time. Would have to see a diagram for your bike.
I also suspect it's that simple.
Later today I'll try to take a picture and post it here
thanks
How would you compare your new 2017 to your 2014?
Suspension and exhaust would seem to be the obvious ones but what say you?
Tks
John
Much better ! Smile
Feels lighter (it's not), shorter (5mm which with my height was just the different between toes and foot on the ground) and smother (somehow seems it curves better... a little to better since it has some oversteering - probably fixed by adjusting the pre load in the front).
Suspension is overall better but a little sportier in the sense that is a little more harder. Again, pre load adjustments might change that although I like to speed and "lay down" on the curves so I prefer like it is
Clutch is significantly better, being very very easy to shift gears (almost no effort on the clutch lever)
Exhaust might be the less practical change, since it doesn't give you any sense of improvement buuuut.... the noise :o those Honda sound engineers know what they're doing and you now have a louder, hoarse noise although maintaining the inline smothness.
Hope it helps Smile
The always on front signals on the US bikes is controlled by the turn signal flasher relay under the gas tank. If he has a 2017 with LED's, he'd have to swap or find the part for the same model year USA bike (assuming the USA bike also has LED's).
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,518 08-16-2025, 05:01 PM
Last Post: bflint
  Workshop Manual and Parts Book 2017 on CB1100's sprint 5 578 01-13-2025, 06:10 AM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 276 08-01-2024, 02:33 AM
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 757 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 993 04-20-2023, 10:17 AM
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 549 12-08-2022, 09:24 PM
Last Post: leung_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,900 07-12-2022, 08:04 PM
Last Post: tommymck
  2013 turn signal replacement RF(OEM) casey66_imp 17 1,281 01-15-2022, 01:31 AM
Last Post: Bazbro_imp
  Turn Signal Malfunction billyfinchapel_imp 5 560 05-04-2021, 01:51 PM
Last Post: billyfinchapel_imp
  rear signal assembly cj599_imp 14 1,022 03-19-2021, 08:14 AM
Last Post: cj599_imp
