Torque values for replacing Front fork top caps please
This is what fork oil looks like in 3 yrs and only 2500 miles . My other bikes didn't look so dark even after 5yrs and 10-15k miles ..
Replacement pro Honda 5w looks much lighter
Wonder what the front fork oil in my ST looks like after 8 years and 86,000 miles lol
ah! did not even consider that the roads may suck near you... the things we take for granted!
(02-24-2017, 05:31 AM)jimgl353_imp Wrote: ah! did not even consider that the roads may suck near you... the things we take for granted!
Roads? What roads? All we ave are streams now...lol.
You know... if someone had a spare set of fork tubes; I'd be willing see if it's possible to drill, mill & tap a hole on the bottom for a drain bolt/sealing washer.
Just thinking Idea
(02-25-2017, 01:08 AM)Razor_imp Wrote: You know... if someone had a spare set of fork tubes; I'd be willing see if it's possible to drill, mill & tap a hole on the bottom for a drain bolt/sealing washer.
Just thinking Idea
That's a very interesting thought Thumbs Up
Having to disassemble the entire front end to change the fork oil is such a PITA and why it rarely gets done.
yeah, but if you just drain it like that, a lot of the crud stays in there.
Update:
I Just cleaned out the stock dirty 10w fork oil and replaced it with 5W honda fork oil ...
Took a few rides in the local twisties and the rough local roads and 5W fork oil was the right way to go not the other 10/15/20 grades .. Very smooth and comfy on rough pavement and no more bouncing high rebound feel from the stock 10w fork oil
Settled on 4 circles showing on front preload and second softest setting on rear for my 185-190 weight with gear and very nice soft and plush feeling without bottoming out at all even in heavy front braking
I'm still wondering why the stock springs are considered too soft for this weight range with preload within range .. For my skills and preference the 5w oil is a fantastic solution to smoothen the ride
I once used auto tranny fluid (ATF) on a 1978 CB750 forks and that felt better so will try the ATF next fork oil change
  Front Fork Springs sprint 1 396 05-28-2025, 03:17 PM
Last Post: SadRodBearing
  Front Fork spring rate? sprint 0 271 05-09-2025, 12:23 PM
Last Post: sprint
  Torque value question Jonnyteabag_imp 9 680 03-10-2023, 01:00 AM
Last Post: 1973cb750
  Milage when replacing chain and sprockets Frulk_imp 8 686 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  spark plug caps alexzanutto_imp 3 423 01-29-2023, 06:21 AM
Last Post: artashline_imp
   Bent front fork? Coronado_imp 15 1,273 04-04-2022, 02:07 AM
Last Post: Mtneers
  Question on replacing engine side cover Ollie 11 826 01-10-2022, 11:21 AM
Last Post: Ollie
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,288 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 656 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 433 04-03-2021, 01:35 AM
