 Beam adjustment screw :)
(02-13-2016, 04:15 AM)rbike_imp Wrote: I haven't done it, but I assume the vertical adjustment is done by the headlight case side mounting bolts/screws.
you mean the bolts at the 'ears'
as you might know and see they make the light go up or down = horizontal
Just in cas, you never know.vRolleyes
Horizontal
[url=https://picoolio.net/image/IdZd][Image: 145d9ff5b0ae6da52798b451f28dfbb2.jpg]
Vertical
[url=https://picoolio.net/image/IdZq][Image: ad35dedf6d4476a31735f7d6ad63f6c1.jpg]
(02-13-2016, 02:48 AM)The ferret_imp Wrote:
(02-12-2016, 06:39 PM)Riko_imp Wrote:
(02-12-2016, 10:50 AM)The ferret_imp Wrote: Hmm I was looking at the hand and camera reflection and that white line, and they all looked the same. Didn't notice the rim pivoting horizontally, although I clearly see that now. However, I also don't understand how the horizontal adj has anything to do with the vertical adjustment.
it has nothing to do with it Smile I was just mentioning that there are 2 adjustment options for the direction of the headlights.
Adjust up and down at the 'ears' its horizontal
Left to right adjustment is vertical....
(02-12-2016, 11:48 AM)Bob Sdaman_imp Wrote: On a bike where the headlight turns with the bars, I was at first baffled as to why Honda thought this adjustment was necessary. But the more I thought about it, I guess it makes good sense. Even if they attempted to make them perfectly straight from the factory, could there be a margin of error? This allows each bike to be adjusted to a suitable or desired precision.
Though I hate to admit it, I found this adjuster screw by accident. When I first went to disassemble the lamp to install the LED, I started here first.
After turning and turning and turning for what I found to be much too long of a time, there it was.....my headlamp was awkwardly turned hard to the left.
Definitely one of those "ah ha" moments.
indeed, i thought it was funny when i discovered that tweak option Smile
I accidentally discovered it too when removing the headlight assembly Smile
Man, I really misread this thread. When you said
"So it allows a vertical adjustment rather than the known horizontal adjustment."
I thought you were talking about that screw allowing a vertical adjustment.
my bad
English, tough language
Left to right adjustment is vertical.... my bad
nah, don't bother, I do it all the time in Dutch too
All this time and nobody corrected the error?
Vertical is UP & DOWN- Horizontal is LEFT & RIGHT- like the horizon...
whatever, point was, the screw adjusts the left/right sideway direction of the headlight
ver·ti·cal
ˈvərdək(ə)l/Submit
adjective
1.
at right angles to a horizontal plane; in a direction, or having an alignment, such that the top is directly above the bottom.
"the vertical axis"
synonyms: upright, erect, perpendicular, plumb, straight up and down, on end, standing, upstanding, bolt upright
"workers enter through a vertical shaft"
2.
archaic
denoting a point at the zenith or the highest point of something.
noun
1.
a vertical line or plane.
"the columns incline several degrees away from the vertical"
2.
an upright structure.
"we remodeled the opening with a simple lintel and unadorned verticals"
hor·i·zon·tal
ˌhôrəˈzän(t)l/Submit
adjective
1.
parallel to the plane of the horizon; at right angles to the vertical.
"a horizontal line"
synonyms: level, flat, plane, smooth, even; More
2.
merging companies that are engaged in the same stage or type of production.
"a horizontal merger"
noun
1.
a horizontal line, plane, etc.
  Valve Adjustment Shims dave 13 709 07-28-2026, 12:49 PM
Last Post: MagnaRider
  JIS screw drivers Ridem32_imp 26 1,733 06-12-2026, 06:56 PM
  Valve Adjustment and Camshaft Removal dave 5 636 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 869 08-29-2025, 10:46 AM
  Valve Adjustment Intervals CBRider_imp 32 3,033 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,161 04-04-2024, 08:18 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,620 11-22-2023, 08:25 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,555 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Front forks adjustment Olyrider 5 527 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Brake reservoir screw head issue satchit 72 5,435 04-24-2022, 11:55 PM
