I fixed my clunky-shifting transmission
I will try this because my 13CB1000 is even "clunkier" than my 78CB750. The one thing I can not figure out is; at times I am stopping without down shifting, and the trans gets lost between some gear and I have a heck of a time getting it to downshift out of the "twilight gear" zone. If i let out the clutch a little it will really clunk and then I can finish shifting it to 1st or it just remains in the no gear ( not netural) and I have to keep stepping on the shifter. I want to try up shifting it sometime when it does it but it always seems like I am in traffic and my brain just want to get it going.
(10-24-2017, 01:32 PM)Flynrider_imp Wrote: I usually use DuPont Chainsaver on both my CBs and it works great. I have noticed that when I'm on trips and have to buy whatever chain lube I can find (usually a light silicone or teflon lube), I often end up with something that my chains don't like.
I haven't noticed problem with shifting, but when taking off from a dead stop, I can feel the chain clunking and it's noticeably noisier.
I've vowed to pick up some travel sized cans of Chainsaver in the future. One less thing to worry about when on the road.
I used a wax based lube on the X chain on the 2012 Bonneville...when I finally lubed it a 6,000 miles. It had no issues at 6,000 miles, but since I washed it, I lubed it.
For the last two Yamaha dual sports, PJ1 every 300 miles. That can is almost empty and I have in stock Dupont Chain-Saver Wax-Based Chain Lube.
It is much cheaper than a new O-ring chain, so I will probably lube it every ~500 miles.
  Shifting issue Cormanus 31 2,422 05-15-2024, 12:59 AM
  Smooth shifting DougsZ28_imp 16 1,433 07-09-2021, 07:32 AM
  No clutch shifting Mixagon_imp 26 1,812 06-21-2021, 10:35 AM
Last Post: cj599_imp
  Trouble shifting CB1100AZ_imp 27 1,977 03-01-2021, 08:25 AM
  Transmission power routing and speeds LakeWylieJoe_imp 6 656 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,283 02-11-2019, 01:55 PM
  cb1100 swingarm play fixed max 5 405 09-28-2017, 09:42 PM
  clanking when shifting PilotPaul_imp 53 3,752 11-09-2016, 05:29 AM
Last Post: Ulvetanna_imp
  Bike stalls shifting into 1st gwallis_imp 19 1,278 11-07-2016, 04:10 AM
Last Post: kennyw
  Trouble With Shifting From 1st to 2nd & 2nd to 1st goldeneye_imp 14 931 09-26-2015, 05:31 AM
Last Post: wiredgeorge_imp
