Suspension, have plan but input appreciated
(03-05-2018, 11:51 AM)PowerDubs_imp Wrote: If you are after a smoother ride, especially on hard bumps I would suggest swapping your entire front forks to the '17 SDBV units. Much better.
Not only are they a easy quick direct bolt on- but this way you can sell your stock forks to offset a good chunk of the cost.
The Trax kit is more of a stiffer sporty ride from all what I have read. Unless that is what you are going for?
I *thought* I didn't have a problem with the rear shocks until I put on the 17 forks...then I noticed the rear on hard bumps more so. So I put Ikons on the rear. Also better than stock.
I remember reading about your upgrade to the '17 forks. If it's not too much bother - what was the final cost?
I'm going for comfort which would lend itself more to the '17 forks but the roads are really, really bad here and I bottom out frequently on both the front and back (but more so the front I believe) which I think (again my knowledge of suspensions peaked when I wrote the word "suspension") would require a stiffer, sportier spring?
For the rear I am definitely going Ikon. I like the Gears-Dynamic shocks (forum member Camoto has a thread on them) but they might be more than I really need.
[Image: dee16ababfbe72ff51ddd177d10d1275.jpg]
If you use the Babbits phone app and that code you get 10% off.
(03-05-2018, 12:40 PM)PowerDubs_imp Wrote: [Image: dee16ababfbe72ff51ddd177d10d1275.jpg]
ROFL You lost me at "phone app", I am somewhat of a luddite - I have a 10yr old flip phone that you can call in or call out. That's it. And I share it with my wife.
But all is not lost, I found Babbitts website and I'm going to order the '17 forks tomorrow.
Thanks Powerdubs!
Worth having a look at the Hagon Nitro rear shocks as well. They have a website and a distributer in Cali. I've got them on the rear and they are very good and great value. Comp and rebound damping. You can choose your spring to fit you weight too.
I went with Andreani in the front. You get a completely adjustable front end with as much or little comp and rebound damping as one could ever need.
I really like them. Riding around London, I sometimes think I'd be better off with a MX bike, between the potholes and the speed bumps.
My front end now takes the bumps well but with little diving on the brakes. It steers perfectly too.
Thanks Beardy, I'll look into those rear shocks.
I did it - I ordered the '17 front shock assemblies, a little more (ok, a lot) more than I wanted to spend though. The discount code wouldn't work, I think it may be for the US only.
Discount code only works if you use the mobile app on the phone or tablet such as an iPad.
I ordered from a tablet, not an IPad though. Every time I punched in the code the country selector would automatically switch to the US and give no other choices.
PowerDubs , I assume you put the 2017 forks on a 2014 , as they might not fit the 2013 ?
Yes, my bike is a 2014. You have to check the parts breakdown, but I am pretty sure nothing changed on the front from 13-14.
The rear did change- axle diameter, etc.
It might perhaps make sense to put 2017 front forks on my 2014.
If the Adreani units need upkeep than they might not be for me.
I am not great in replacing the fork oil on my bikes.
It used to be very easy years ago when the forks had little drain plugs on the bottom.
  Suspension Static Sag ozigoo 27 1,880 05-12-2021, 02:05 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 670 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Race Tech Gold Valves in stock suspension ozigoo 9 695 06-24-2020, 03:59 AM
  Stock Suspension Adjustment riggies_imp 28 2,172 10-16-2019, 02:08 PM
Last Post: jdvalero_imp
  Lower suspension apehair_imp 3 380 08-26-2019, 11:51 AM
  Would love some input on the install of the factory heated grips. Tim_imp 2 342 05-06-2018, 03:08 AM
Last Post: Tim_imp
  Setting up your suspension spacetiger_imp 17 1,032 01-25-2016, 05:38 AM
Last Post: ChipBeck_imp
  2014 CB1100EX Front Suspension: It’s different spacetiger_imp 7 524 01-11-2016, 12:49 PM
Last Post: rboe
  Weird Suspension Design Paulb_imp 18 1,311 01-10-2016, 06:55 AM
Last Post: HBFL_imp
   Tyre (Tire) Pressures and Suspension Settings Tortuga_imp 10 789 03-24-2014, 08:34 AM
Last Post: Tortuga_imp
