Likes Given: 1,010
(04-22-2018, 03:52 AM)Lord Popgun_imp Wrote: You don’t have to take the gasket off the old filter, just make sure it is on it. If not, peel it off the engine!
You’ll all kinds of advice on the center stand. And if you don’t know how to do it, you could drop the bike. So don’t be paranoid.
The deal is, push the stand down with your right foot. Then lean the bike up until BOTH legs are touching the ground. Then you can hold the left handlebar grip with your left hand (and front wheel straight) and push down on the stand while using your right hand to pull up while holding the grab bar or rack bar if you have a rack. Use your weight on the center stand and the bike will pop right up. Your friend can show you. Its easy.
The real fun is if you get a heavy bike like the ST1300. That one is hard for me. But it comes up.
Getting it down. Well, I’m a small guy so I sit on mine and rock it off. Some just hold the handlebars and push. That ain’t me
Me too. I also grab some front brake as the stand pops up.
Threads: 25
Likes Received: 28 in 8 posts
Likes Given: 1
I’m in Fountain Valley. I get my oil, filter and crush washer at Huntington Beach Honda. What part of Orange County are you in?
Likes Given: 142
(04-22-2018, 06:03 AM)Cormanus_imp Wrote: (04-22-2018, 03:52 AM)Lord Popgun_imp Wrote: You don’t have to take the gasket off the old filter, just make sure it is on it. If not, peel it off the engine!
Yeah, me too.
Threads: 22
No need to feel paranoid about using the center stand. Done incorrectly could definitely result in a tip over. It took me a while to be able to do it confidently. Also worth noting that I am pretty light at 155 lbs so a heavier person will have a much easier time with it. It is ALL about putting weight straight down on the center stand foot platform, which acts as a lever and lifts the bike up and backwards. I will stand completely on the center stand with all my weight, meaning my other (left) foot is suspended in the air. My weight alone is not enough to do the trick so pulling straight up on the grab rail is necessary to get it the rest of the way up. From there its a nice fluid motion of the bike moving up and backwards. Commiting to the task and being fluid are important. As are having your bike on a flat, level, hard surface. You'll get it with a bit of practice.
Getting it off the centerstand is a bit easier. I usually get on the bike , right foot on the foot peg, left foot on the ground for leverage/balance. Then just heft your weight forward pretty hard and the bike will roll forward off the stand. Cover the front brake with your hand to prevent it rolling forward too far if something is in front of you.
Also oil changes on this bike are a breeeeze.
Threads: 25
Likes Given: 1
Exactly as dbarkdoll says. The difference for me is that my grab bar is blocked by saddlebag so I reach down to passenger peg mount and pull up from there. The main thing is pushing down on the stand. One other thing, I ALWAYS start from the bike on its side stand, push center stand down to the ground and then push bike to get both feet of center stand on the ground. Then push down on stand while lifting.
Threads: 3
thanks for all the tips, i read them all and watched the youtube vids a few times and went to the garage and it wasnt as bad as i thought it would be lol!! Im probably going to sit on the bike to rock it off just to be safe .
https://imgur.com/a/b2wEwbQ <-- i did it ! haha
(04-22-2018, 06:11 AM)MMC_imp Wrote: I’m in Fountain Valley. I get my oil, filter and crush washer at Huntington Beach Honda. What part of Orange County are you in?
La Habra
Threads: 186
(04-22-2018, 12:17 AM)PowerDubs_imp Wrote: Although I have filter cap tools to fit just about any size- I don't use them any more.
I have had several times that I end up fighting with an oily messy used filter to get it back out of the cap.
I purchashed a set of filter pliers a few years ago and love them. Like these-
https://www.autozone.com/shop-and-garage...141500_0_0
![[Image: f9a46610e40a66b54388334b9b174ae7.]](https://cb1100forum.net/forum/uploads/imp/201804/f9a46610e40a66b54388334b9b174ae7.)
Also something else learned from years of working on stuff- I now use a tq wrench on a lot of things when I never did as a kid. And yea- there was times I had to deal with stripped stuff.
It is pretty common on cars for shop monkeys to strip the oil pan plugs. If you have never wrenched on anything before, take the time to do it right and start with good habits instead of learning by mistake.
Threads: 22
(04-22-2018, 09:02 AM)LordWasr_imp Wrote: thanks for all the tips, i read them all and watched the youtube vids a few times and went to the garage and it wasnt as bad as i thought it would be lol!! Im probably going to sit on the bike to rock it off just to be safe .
La Habra
La Habra
Nicely done. Now that you've done it once it will be a breeze from here on out.
Threads: 3
Woot Woot !!! Quick question, if I take the gas tank off should I wait til I have 1 bar left? The reason is because I'm installing the battery tender quick dissconect chord & also the adapter for a USB . I was thinking to run the iPhone cable underneath the gas tank and pop the charger out in middle. I saw a video on how to take the tank off where you unplug 2 tubes but not sure on what to do if there's still gas in the tank lol.
Thanks in advance !!
Threads: 17
Likes Received: 5 in 1 posts
(04-22-2018, 11:37 AM)LordWasr_imp Wrote: Woot Woot !!! Quick question, if I take the gas tank off should I wait til I have 1 bar left? The reason is because I'm installing the battery tender quick dissconect chord & also the adapter for a USB . I was thinking to run the iPhone cable underneath the gas tank and pop the charger out in middle. I saw a video on how to take the tank off where you unplug 2 tubes but not sure on what to do if there's still gas in the tank lol.
The fuel line connector automatically prevents any fuel leaking when it's disconnected. You will only spill a tiny amount that is in the line. Other than the additional weight of more fuel in the tank you can remove the tank whenever you like. I prefer to do it whilst it is as empty as possible because it's easy to manage the lighter it is.
