Fuel Pump problems ?
Max's suggestion about swapping relays is a good idea.
Before the swap, a gentle tap on the fuel relay with the handle of a screwdriver (mini mallet) may bounce the contacts to allow the fuel pump to activate.
If that works, go ahead and replace the relay.
(07-06-2018, 01:31 AM)SportsterDoc_imp Wrote: After you check Popgun's advice in PP 2 & 3 of post 2, including unplugging and re-plugging the connector and insuring at all the pins/sockets are fully engaged in the connector cavities, then if that does not solve the issue, swap the two relays.
I do not know about the 2013, but the 2014 standard has a 4 pin connector (to accommodate the fuel gauge).
Yellow/red changes to brown at the connector, then goes to the fuel pump relay for power.
Black/white changes to green/black at the connector, then goes to ground.
If the ground is clean, as Popgun already suggested, the pump can be tested by powering the yellow/red wire, while grounding the black/white.
I am sure Popgun will advise if the 2013 schematic is different.
2013 fuel pump assy has a flat, 3 pin connector, versus square 4 pin for 2014 Tongue
AND I bet 1x U$100 ca$h that there is NO real corrosion Smile
  Delkevic 9" Oval Install Problems. jbird06_imp 4 461 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Fuel pump, yes really. GUNFTR_imp 13 1,160 01-02-2024, 01:11 AM
Last Post: SportsterDoc
   Light problems/electrical Dude_imp 6 570 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Fuel Pump Alternatives SamWhited_imp 13 1,044 07-11-2023, 08:52 PM
Last Post: The Gecko_imp
  Fuel pump noise? Ben70_imp 15 990 07-16-2022, 12:22 AM
  fuel pump automotive equivalent battaglioa01_imp 0 194 11-19-2021, 02:11 AM
Last Post: battaglioa01_imp
  fuel pump whine battaglioa01_imp 2 343 11-18-2021, 05:30 PM
  Bad fuel pump- jdgrego1_imp 33 2,432 11-20-2020, 03:07 AM
  Intermittent fuel pump QUINTtastic_imp 4 420 06-15-2019, 12:17 PM
Last Post: QUINTtastic_imp
  Rear Wheel problems Sfomoto_imp 30 1,833 01-05-2019, 11:15 PM
