Intermittent fuel pump
Hi all. My bike stalled in traffic recently, the dealer replaced the fuel relay. Now it has been intermittently deciding to start. Sometimes when I turn the key, it all cycles and pressurized, other times, not a peep from the fuel pump. Any ideas? I have the telephone book size manual for the bike but I’m really hoping to not have to take apart the tank and pump. I’m only at 12500 miles
QUINTastic, check back to [url=http://cb1100forum.com/forum/showthread.php?tid=14332&pid=241508#pid241508]this post from max. I can't find the post from Flynrider that max references. I'd start with the kill switch.
Have you eliminated the kill switch? I and a few others have had similar problems due to corrosion on the contacts.
The easiest way to rule out the kill switch is to watch for the 'check engine' light when you turn the key and don't hear the fuel pump. Normally, the check engine light will come briefly as the fuel pump cycles and the gauges sweep. If you don't see the check engine light come on and you don't hear the fuel pump cycle, the problem could be an intermittent connection in the kill switch.
Edit : Here's the last page of my previous post on the kill switch issue.
http://cb1100forum.com/forum/showthread....#pid185209
Attempted to delete my response, as this was well covered by Max in Cormanus' post two link and Flynrider in post three link...while I was typing.
(06-15-2019, 09:53 AM)Flynrider_imp Wrote: Have you eliminated the kill switch? I and a few others have had similar problems due to corrosion on the contacts.
I haven’t eliminated it yet. I was in the process when my neighbor came over to chat. The process involves unplugging the kill switch and right side controls from in the headlight. But one even more odd thing is that it has started without the fuel pump pressurizing before.. possibly because it still has pressure, I don’t know.. but I have this slew of things to go over before I buy a pump
Also- twice it has started and died after a few seconds.
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 510 01-30-2026, 02:16 PM
Last Post: JRD
  Fuel pump, yes really. GUNFTR_imp 13 1,116 01-02-2024, 01:11 AM
Last Post: SportsterDoc
  Fuel Pump Alternatives SamWhited_imp 13 1,020 07-11-2023, 08:52 PM
Last Post: The Gecko_imp
  Fuel pump noise? Ben70_imp 15 983 07-16-2022, 12:22 AM
  fuel pump automotive equivalent battaglioa01_imp 0 190 11-19-2021, 02:11 AM
Last Post: battaglioa01_imp
  fuel pump whine battaglioa01_imp 2 340 11-18-2021, 05:30 PM
  Bad fuel pump- jdgrego1_imp 33 2,411 11-20-2020, 03:07 AM
  Intermittent Tick and skip a beat zirconxi_imp 4 412 09-27-2019, 11:04 PM
  Fuel Pump problems ? sharkyo4_imp 11 757 07-06-2018, 10:02 AM
  Torque Specs for fuel pump Mscb1100_imp 5 489 03-13-2018, 03:38 AM
Last Post: Flytech99_imp
