Slipper Clutch for 2014 base model
(10-25-2018, 08:39 AM)Bradders_imp Wrote: I like the roll into roundabouts sustained rpm,makes it mega smooth in and out. It works well with the smooth easy changing gearbox. Bikes feels likes its got an electric motor.
After the initial back-off, does engine braking feel the same?
There are a couple times I went off-the-line WOT on my Moto Guzzi V7II, hit close to redline, but had to back-off, instead of shifting and was quire happy to have full engine braking...albeit hard on the rear tire.
(10-25-2018, 08:42 AM)peterbaron_imp Wrote: Maybe ZZR & GSX slipper clutch is better than CB but there is no way that that CB would take any other than 1st place after all Big Grin
I said the cb slipper was better than the other two models? Wink
That is correct, my bad , I misread you sir Smile
(10-25-2018, 08:52 AM)peterbaron_imp Wrote: That is correct, my bad , I misread you sir Smile
To be fair the gearbox shift mechanism knocks spots off the others too. So does the grunt from 1200rpm. Its the most amount of miles I’ve done on a bike in years!
Beer
The engine braking feels just right. It's like you were releasing the clutch just at the grip limit so the rear tyre won't slip even with agresive engine braking. It does "engine brake", but not abruptly.
It really works very well.
I've read some reviews complaining about the noise it makes. I can hardly hear it, and only at "parking speed" with the helmet visor open.
Is it worth it? well, like ABS, it's good to have it in case you make a driving mistake, or during some unexpected situations.
On a cardan drive, I think it would be a great addition to smooth out engine braking. On a chain drive with the fat tyres of the RS, I think I could live without it.
If you go down a number of gears in quick sucession it allows you come flying off the apex. This is not something thats possible with no slipper unless its mapped into the closed throttle, like extra fuel or timing or a dbw throttle lift.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,249 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 974 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,061 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 239 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Cam chain model and relpacement. syncronizator_imp 19 1,712 10-20-2023, 08:45 PM
  Clutch Fluid Wagonpeddler_imp 32 2,509 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 634 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,154 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Clutch pull mpuhl_imp 4 508 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 387 01-27-2023, 12:33 AM
