Draining oil from Airbox drain hose. Frequent Oil accumulated.
I do both 2x/year, based on 15Kms
Checked mine today, little over 10,000 miles. Didn’t drain a drop. 2013 standard.
Bone dry since new. Never saw a whiff of oil in there.
guess I should figure out what this is and check it...
are you talking about removing PLUG, BREATHER TUBE
17370-382-870 from TUBE A, DRAIN 17366-428-670 and seeing what comes out?
(11-26-2019, 05:23 AM)Csory_imp Wrote: Bone dry since new. Never saw a whiff of oil in there.
+1
2014 Honda CB1100 DLX
2002 Honda CB750 Nighthawk
(11-26-2019, 09:46 AM)jimgl3_imp Wrote: guess I should figure out what this is and check it...
Yes. The smaller one you can see behind the cylinders always has something in it on my bike.
+1
+1
(+1) since 2015.
meant to check it today. just got busy and forgot.
  2014 / 2017 airbox snorkels PowerDubs_imp 52 2,463 02-20-2021, 02:40 AM
Last Post: jimgl3_imp
  Oil Drain Plug Washer Size Tev62 14 731 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 553 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Draining oil : hot, warm or cold Houtman_imp 25 1,039 09-13-2019, 09:57 AM
  PAIR valve hose connections HBFL_imp 2 182 12-17-2018, 06:30 AM
Last Post: HBFL_imp
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 980 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
  interesting conversation about draining oil the Ferret 68 2,235 11-06-2017, 09:58 AM
Last Post: Ole_imp
  Best way to drain fuel tank? Rebel73_imp 10 426 08-08-2016, 08:18 AM
Last Post: Rebel73_imp
  Water in breather hose Speed_imp 5 244 04-20-2016, 07:31 PM
Last Post: Pterodactyl_imp
  Magnetic oil drain plugs 4 Paws_imp 3 197 02-25-2016, 09:21 AM
Last Post: Obleo
