Draining oil : hot, warm or cold
This has been discussed before I think but there was a good article in
Road Racing World (sept. 2019 ) Excellent magazine for people interested in racing.
I always drained my oil hot but will change to draining it cold.
Short of the story : Drain Hot 4.5 % oil left
Drain Warm 6.8 % oil left
Drain cold 0.3 % oil left
Use the gravity, Luke.
yea I brought up this subject back in 2015
http://cb1100forum.com/forum/showthread....t=oil+cold
btw i'm still draining my oil warm. Old habit die hard ...and I believe it's what the manufacturer (and nearly every one else in the world) recommends.
^^ +1, hot drain here as well, and let it drip for some time....
Draining oil when cold is counter-intuitive ( hot oil is more viscous and 'runny' ) but I could understand that, when cold, the oil will cling better to itself, with gravity pulling it out better as a whole.
Also, workshops are under time pressures and the bulk of the oil will drain quicker presumably, than waiting... and waiting... and waiting for cold oil
The reason for draining oil cold is that all the oil is in the sump and all the contaminants will be in that oil. If still hot some of the "baddies" will still be in the engine. I always drained it hot ( including burns ! ) but from now I will drain it cold to see if more old oil will drain out.
(09-12-2019, 03:29 AM)Bazbro_imp Wrote: Draining oil when cold is counter-intuitive ( hot oil is more viscous and 'runny' ) but I could understand that, when cold, the oil will cling better to itself, with gravity pulling it out better as a whole.
Some of the better shops put the bike in a cooler for a while to get the oil cold.....
I drain it hot and let it drip over night. Then it's cold in the morning.
Interesting numbers. Warm is the worst option?
(09-12-2019, 07:28 AM)Cormanus_imp Wrote: Interesting numbers. Warm is the worst option?
Yes, warm was the worst , it was a well done test with great accuracy.
The difference between the hot and cold percentages is enough for me to consider doing it cold from now on.
  Low rattle on cold start. shahyaan_imp 22 1,556 11-30-2020, 12:01 AM
  Cam chain rattles when cold Speed_imp 24 1,526 05-28-2020, 05:41 AM
  Cold Weather & Tire Pressure 2017EX_imp 22 1,257 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Draining oil from Airbox drain hose. Frequent Oil accumulated. zirconxi_imp 17 1,097 11-27-2019, 09:17 AM
Last Post: jimgl3_imp
  Cold start idle rpm pittycheria_imp 11 761 12-26-2017, 03:16 AM
Last Post: Wisedrum
  interesting conversation about draining oil the Ferret 68 3,543 11-06-2017, 09:58 AM
Last Post: Ole
  Engine sound when is cold Speed_imp 4 379 04-07-2016, 10:16 PM
