 Engine light Blinking
I was forced to the service manual. The MIL blink system has no capacity to display the sub code. You need a proper tester apparently.
Yet again, Lord Popgun correct is.
(11-27-2019, 07:30 PM)max_imp Wrote: Tory glad it is fixed, what was the repair? we would like to knowThumbs Up
Cormanus i was hoping houtman would chime in and cleared this up because the1 and 2 stands for two different faults.
i guess it is another short flash after the 23 code but i have not seen any example of this, i wondered the same thing.
A mechanic at my local dealer checked the error code on my 2017 but I did not hear about the code number . The check engine light was blinking because I had installed a o2 sensor eliminator on my 2017.
Running perfect after removing the eliminator and resetting the code.
Should feel blessed that Honda would even be generous enough to flash anything at the owner. Pretty fair.
Some other manufacturers hide the code behind a technician's passphrase on the instrument cluster.
I noticed similar functionality when correcting the ECU on my Monkey for altitude. Going through the diagnostics requires an "SCS Service Connector" jumper on the DLC (Data Link Connector), but once in place, it's easy to observe the different settings on the MIL as you cycle through. It's not unlike reading morse code. It'd be difficult to know what the codes meant without access to the service manual.
Interesting topic! On my Moto Guzzi Griso the dash display can give the error code # (if there is any) after the service code (which is not a secret) is entered. I now realise that this is not as easy for the CB1100.
Also, for Moto Guzzis there exists a diagnostic software program called "Guzzidiag". You can connect your laptop runnning Guzzidiag to the bike and you can then diagnose (and change) more than you ever wanted. A very handy piece of software. Is there an equivalent sofware for Hondas?
(11-28-2019, 03:16 AM)bioman_imp Wrote: Interesting topic! On my Moto Guzzi Griso the dash display can give the error code # (if there is any) after the service code (which is not a secret) is entered. I now realise that this is not as easy for the CB1100.
Hey ... that sounds pretty awesome.
Is the connection physical or wireless?
I have similar functionality for my BMW's, but it's wireless through my cell phone. It allows you to scan and reset fault codes, update service reminders, monitor engine parameters, test sensors, cycle the ABS pump when flushing the brakes, etc.
Run it in LR, rub it in Big Grin
I have to hook up my Healtech code reader and connect it to a PC. I wonder if they could make one that worked on Bluetooth to a phone. Hummm, might have to email them that request.
...and you will wait for your answer forever, from Honda, I meant
(11-28-2019, 03:29 AM)LongRanger_imp Wrote: I have similar functionality for my BMW's, but it's wireless through my cell phone. It allows you to scan and reset fault codes, update service reminders, monitor engine parameters, test sensors, cycle the ABS pump when flushing the brakes, etc.
Man. That is just incredibly sweet.
Makes me want to hack the CB1100. Csory? Wad you think? Big Grin
Photo First Check Engine Light Ever on a Bike doug1976 2 229 01-14-2026, 06:47 PM
  engine light tpo12001_imp 16 1,424 01-14-2026, 05:26 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,261 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
   Light problems/electrical Dude_imp 6 592 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 431 07-03-2023, 10:18 PM
   Ticking noise from top part of engine Kingkong_imp 40 2,778 03-18-2021, 01:22 AM
  check engine light stays on, on my 2017 Houtman_imp 51 3,412 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  running light and brake light Ennsync_imp 3 429 01-02-2019, 11:24 PM
   H4 Head light Bulb Question Ennsync_imp 36 2,509 12-30-2018, 01:48 PM
