engine light
The engine light came on after the low fuel sensor started blinking,after I fueled up the engine light is on,how can I reset it?2017 cb1100ex
Tpo,
It is not hard to do but there is a little procedure. You will need the SCS service connector (a shorting plug) or a paper clip or jumper wire to short 2 pins on the DTC connector.
We cannot post copyrighted material here so if you will PM me your email address I will send you a pic of the service manual that shows and tells and shows you the simple procedure. And I will tell you which wires to short as the procedure uses the SCS connector. And no one seems to have one, except me Big Grin
Came with the Ring, did it? Tongue
http://cb1100forum.com/forum/showthread.php?tid=18018
https://www.youtube.com/watch?v=iwSllBQNsWc
https://smartmoto-electronics.com/smart-...ch-dmt-003
Welcome Karidis. The video is courtesy of our very own Max.
Hey! Welcome to the Forum Karidis.
(09-05-2023, 12:14 PM)Cormanus_imp Wrote: Came with the Ring, did it? Tongue
That thing does come in handy once in a while.
Good Day Max, how come your CB comes with "HISS" system, was that CB imported from Japan or other countries?
Hi tpo,
I cannot tell from your post, if you have ridden the bike after the engine light came ON.
If not, go for a 5 minutes ride. On my EX this tames the engine light in the following minor cases (as I have learned the long way):
- after a dead battery has been replaced
- after running out of fuel and adding fuel
My assumption is, to the ECU both of these 2 condition look exactly the same. The lack of fuel pressure is responded to with the FI light coming on.
Hope this helps and you don't need to invest in buying or making a service connectors etc.
BTW, I like tpo as it reminds me or 3po in starwars Wink
Photo First Check Engine Light Ever on a Bike doug1976 2 218 01-14-2026, 06:47 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,215 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 420 07-03-2023, 10:18 PM
   Engine light Blinking tory_imp 25 1,693 12-04-2019, 10:38 PM
  check engine light stays on, on my 2017 Houtman_imp 51 3,265 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 325 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  running light and brake light Ennsync_imp 3 404 01-02-2019, 11:24 PM
  Check engine light/codes Carguy1959_imp 17 1,087 08-24-2018, 03:00 PM
  Oiltemp,check engine and hiss light thomasdebess_imp 7 537 09-12-2015, 10:28 AM
Last Post: flynrider
  Engine quit at stop light sanoke_imp 41 2,456 08-05-2015, 11:30 AM
Last Post: sanoke_imp
