Replaced front brake pads for 1st time at 20K miles
(01-03-2020, 01:13 PM)E11even_Hunnit_imp Wrote: Speaking of pads, has anyone here done EBC pads?
Just curious, cause honestly the braking on this bike needs nothing, I'm so happy I ended up getting a non ABS model Celebrate
Hopefully you never have to wish that you would have had ABS brakes !
I replaced mine recently with EBC pads. Seem every bit as good as original and cheaper.
FWIW I've been using EBC on several bikes with good results.
I fitted an EBC kit of disc and pads to my Bonneville front wheel and there was an improvement in braking.
It wasn't a difference in night and day improvement, but enough to make it worthwhile.
I've heard from mechanics up at the shop that the EBC's are thinner, don't last as long as oem, and wear the disc more. Personally I'll stick with oem.
^^^^ +1, 've been in automotive business for almost 4 decades ....and the bottom line for me is OEM...+ less headache..
(01-04-2020, 12:48 AM)The ferret_imp Wrote: I've heard from mechanics up at the shop that the EBC's are thinner, don't last as long as oem, and wear the disc more. Personally I'll stick with oem.
I use EBC Sintered on all may bikes. They, in fact, last longer than OEM and have a better "bite" due to the materials used. They also resist heat better from my experience. They will, however, wear you rotor more due to more friction from the compound of the pad.
TBH I haven't changed the CB's pads yet as I've only got 9K on her. When I do I'm not entirely sure I will change the front to EBC Sintered as it has enough "bite" as it is. The rear will be changed over.
  Brake Pads... Simplified Yata-Garasu_imp 20 1,771 03-02-2025, 08:28 PM
  Front ABS Brake"Rain Stick" noise bflint 3 453 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Front brake inconsistent resistance ChiefJP_imp 16 1,355 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 940 06-14-2023, 07:34 AM
  Front brake lever ROCK hard ichiban_imp 37 3,764 02-10-2023, 10:54 PM
  FRONT BRAKE TIGHTER omnimj_imp 2 259 09-08-2022, 02:43 AM
Last Post: 1985CB450_imp
  Any one use Ceramic Brake pads? mvk24_imp 6 645 05-14-2022, 12:53 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,220 03-31-2022, 04:03 AM
  brake pads which is best? modmaster_imp 32 2,250 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Suggested brake pads? mvk24_imp 12 980 03-21-2021, 04:05 AM
