Drive Chain upkeep
(05-18-2020, 12:59 PM)LakeWylieJoe_imp Wrote: Here's short rundown on how it's done. It may not be the best method, but it works for me and it's fairly quick. My last VFR went 36,000mi before I had to adjust the chain tension. I'll try to get a video together the next time I do the job (500mi from now).
Items you'll need: chain cleaner, Honda chain lube (not the white lithium garbage), a piece of scrap cardboard (a section of cereal box does nicely), and a scrap piece of terry cloth. I've cut up old beach towels and gotten about 8 nicely-sized segments, or WalMart sells inexpensive terry cloth shop towels in large rolls.
Put the bike on the centerstand and lower the side stand, too, in order to create a little more working area.
With the chain cleaner aerosol can (nozzle attached), work on cleaning up the chain in segments about a foot (30cm) long on the lower run between the sprockets. I hold the rag behind the chain to catch all the overspray, then use it to wipe the grime off. Once a segment is clean, I roll the rear wheel to expose the next segment. I'm able to do the whole thing in 3-5min, because there is little grime to begin with. Even so, the rag is mostly black by the time I'm done.
Next I hit the segments , one at a time as above, with the lube (nozzle attached), using the cardboard to catch all the overspray. Once all the links are foamy, I use the remaining clean areas of the rag to wipe the excess off the side links. You can hold the rag around the chain and roll the wheel--the excess comes right off.
I suspect the lube penetrates into the working surfaces of the chain if it's hot when you apply the lube, but I may be wrong. i let the stuff sit for at least 10min or so before riding off.
I toss the rags and cardboard when done. I've had to buy maybe three or four cans of chain cleaner in 5 years and I think I'm still on the original can of lube. When on long road trips, I pack a few rags and sheets of cardboard so I can do the job when it's time.
Anyway, If anyone has any suggestions, I'm all ears.
I just bought a pack that had the Honda chain cleaner and Honda chain lube with "white graphite". Can I assume that's not the same as "the white lithium garbage" or have I been duped by an unscrupulous Honda marketing department? I mean, they put "WHITE GRAPHITE" in yellow yelling font. How is that not automatically better?
I've been spoiled with 7 years of shaft-drive on the BMW and have been using Motorex cleaner/lube on my KTM so it's been awhile since I've had the Honda stuff in the garage.
Oh, gawd, made me look at Honda Chain Lube. What's better: chain lube with "Moly" or chain lube with White Graphite? On price, because it’s more expensive, the white graphite should be.
I've had a can of Honda Chain Lube for a wee while and it recommends spraying it on, letting it sit and then washing it off before re-oiling. It does a pretty amazing job of getting crap off the chain.
I use a damp kerosene rag to clean and 80/90 gear oil for lubing .
Kero to clean and gear oil to lubricate...cheap and efective...Comparison video of chain lube effectiveness below...you'll never buy chain lube again....
https://www.youtube.com/watch?v=VnPYdcbcAe0
Sorry. The stuff I meant to denigrate was the white graphite lube. It's a mess.
I've always used the *Put a rag on the other side *Put a rag on the floor to catch the drips *Spray a section *Rotate *Spray another section method.
A year or two ago, I started using a Grease Ninja: https://www.greaseninja.com/ to do my chain lubrication. It's a simple, "why didn't I think about it" product that puts the lube in the center of the chain, and doesn't get overspray all over the place. It takes less time, too. I put a rag on the floor to catch the drips, lube while I slowly rotate the back wheel, and when I'm done, use the rag to wipe the chain.
Been using Maxima Chain Wax for years, and can't remember the last time I had to do a chain adjustment, other than during tire swaps. I only ride on paved roads in dry weather, so don't have to do much cleaning.
I got 36,909 out of my first CB 1100 chain
(05-19-2020, 01:05 PM)The ferret_imp Wrote: I got 36,909 out of my first CB 1100 chain
Bugs, gremlins, gobs of oil, grains of sand? lol
lol that plus miles
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,206 11-29-2022, 07:49 AM
  Checking Drive Chain Slack Townie_imp 26 1,743 01-15-2020, 11:14 PM
Last Post: cocojamboo_imp
  Drive chain replacement time, probably. Rolls_imp 34 1,911 06-02-2016, 12:59 PM
Last Post: flynrider
  Interesting read on Final Drive Gear ratio's CIP57_imp 10 763 03-24-2016, 03:18 AM
  Got my Drive Sprocket off Pterodactyl_imp 3 277 06-16-2015, 10:27 PM
Last Post: Pterodactyl_imp
  safe to drive 600 mile bike? linuxology_imp 9 566 01-01-2015, 12:52 PM
Last Post: Aussie_imp
