Valve Clearance Cost
(09-30-2020, 02:56 PM)bertypower_imp Wrote: Update: I decided to get the Honda dealer to work on my valve clearances. Thought it would be best. Especially if I dropped something into a crevice or whatever the guys at the shop would have the RIGHT tools for the job. I am very handy but I probably would’ve taken a few days with ordering the correct shims and probably misc trips to get materials etc. I’ve never even done an oil change... first time working on the bike was re-sealing the crankcase covers.
Apparently 9 out of the 16 valves were out/close to out of spec. Enough to get 9 new shims. They did give me the mechanics handwritten notes which I’ll post here and I guess update the master thread here in the forum. If you guys can look at it and make sense of it that would be awesome.
Glad I didn’t put it off any longer. Not sure I need to check it every 8000mi. I think 12,000 miles will he fine?
The problem isn't having the right tools- it is exactly what else you said- you have the time to make sure it is done right, double/triple check and take care.
Shops pretty much never do the same quality of a job that a person would do themselves. Doesn't matter if a car, bike, lawnmower, ....building a house, deck, roof, you name it.
(09-30-2020, 06:54 PM)max_imp Wrote: Thanks Berty i have drawn another list of what i think the technician has done as best as i can decipher it, see what you think;
Interesting that they all were too wide, that may have changed over time but good to know.
cheers.
I think I don't trust that kids work.
Sorry, but wow to both the notes and the 'results'.
There pretty much zero chance you needed 9 valves tightened up.
It is likely the bike is worse off for having that 'work' done.
Problem is you won't hear an issue on it being tight. 'Sounds good, no problem'.
I hope I'm wrong and it runs great for you with no issues for as long as you own it.
cheers.
cheers.
I understand what you’re saying, however, I have no reason not to trust them. They have diagnosed/maintained all my bikes and have done a good job on all. They are also very professional, return phone calls and take time to talk with you about the problems. Also, they do the job in a timely manner and are upfront with the costs.
The bike is not leaking from the gasket anymore, and feels like it runs better, healthier. So I’m happy with it. It hasn’t blown up...
cheers.
cheers.
I think my bike is in that spreadsheet. Had it done somewhere around 19K miles? Was pretty close to factory specs. I take it to a non Honda shop that specializes in performance bikes that are run during track days. Been very happy with them.
If they did everything correctly on your bike you can probably extend your next valve interval pretty safely. Valves being out of spec are not a noted issue with this bike. Wise Drum appears to be at the extreme end of the interval spectrum and his bike is still running strong. I’ll prob have mine looked at again around 40/50K miles.
(10-16-2020, 11:07 PM)Frulk_imp Wrote: I think my bike is in that spreadsheet. Had it done somewhere around 19K miles? Was pretty close to factory specs. I take it to a non Honda shop that specializes in performance bikes that are run during track days. Been very happy with them.
Which is why I don't trust that the guy above had 9 out of 16 out of spec.....and all in the same direction.
The sloppy notes just backed up my feeling...
If a dealer gave me some scrappy paper like that I wouldn't be back, no pride of workmanship whatsoever. This is also a failing in the service manager in the fact he let this information leave his shop like that. If they can't even equip the technician with a printed piece of paper to fill out what does that say about them? I did the clearances on my Triumph this year, luckily shim over bucket, and this is the minimum clearly presented information I would want back from the dealer and I would tell them before the job. Even If they hand handwritten this it would of been OK.
I know for sure the last owner of my Triumph was totally bull@~*^ted on the last valve service and I dread to think how much they charged him for changing the oil and filter and leaving the bike in the back of the workshop for a day pretending to do the work. The bike was in the UK at the time and it was a large, quite well thought of dealer.(not a Triumph dealer) They had the gall to stamp the service book that the valve service was done. 2,000 miles later I open it up and six needed doing, they were never touched. Every owner should ask for the measured clearances and corrective shim sizes used when they drop it off and put the dealer on notice.
The owner could request photos of the clearance operation.
Otherwise, yes, it will be honour-based servicing.
Also, there are usually indicators demonstrating, for example, the head was removed. If the head was removed, then very likely the clearances were at least inspected.
Have had mine checked 3 times about about 12K mile intervals. Cost ranged from $600-$800 dollars each time. All done at reputable dealers. Last time was a fubar result at Motoworld in San Diego area (I got "made-up" valve clearance values reported back to me) . Only one reputable dealer I would trust now and they are backed up from last Feb 2020 because lack of qualified mechanics. Just started doing the 4th check myself last night (Thu); hope to be done by end of day (Sat). Its my first time so I am going slow. Could not have attempted this without all the great how-two knowledge from this forum. Just got off the valve cover this morning. So far this effort has been very educational, plus I can see the shoddy work that Motoworld did at putting everything back together (excessive gasket glue all over the valve cover inside and out, plus improper routing of cables).
Excessive glue could break off and get into a oil passage . It is a terrible shame that you can trust so few shops to do an honest job on our bikes. I never mind paying for quality work but none of us like being ripped off. I am more afraid that they screw up things when checking the valves than leaving it a little longer before checking the clearances. Interesting tread Bill and good luck.
(01-01-2021, 06:28 AM)Houtman_imp Wrote: Excessive glue could break off and get into a oil passage . It is a terrible shame that you can trust so few shops to do an honest job on our bikes. I never mind paying for quality work but none of us like being ripped off. I am more afraid that they screw up things when checking the valves than leaving it a little longer before checking the clearances. Interesting tread Bill and good luck.
Yeah, I hear ya.
Owner: " ... it didn't make those grinding sounds before the last service work."
Shop: "Well, that must be something else with your bike. Drop it off at the shop and we'll do an assessment and report back to you. Assessment shop charge is 1.5 hours labour plus shop supplies ... "
Shop: "We accept cash, and second borns ... "
No-one seems to be truly ‘happy’ with the service they get at dealers or at the very least we are skeptical they did it right. With tolerances so absolutely tiny (I believe +/- 0.03mm) I often wonder if its the actual process of using the feeler gauge that fuels the controversy. It’s very much a subjective task. Is my ‘just right’ the same as yours or would you go ‘no too loose’ for example. Probably, I would expect a main dealer to make more effort with results (a la Tev62) however I could also be very suspicious of a neatly produced document (Billy BS). Given the choice I would prefer to see the scruffy oily notes and speak in person to the technician that did it. They can’t win in a way. I’m fortunate that this dilemma is some time off for me, just out of interest is there anyone on the forum that’s actually had a burnt (exh) valve or had running problems as a result of not getting valve clearances checked? We all know it can happen, but has it?
  Valve Adjustment Shims dave 13 709 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 635 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 869 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 951 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,026 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,547 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,454 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,175 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,575 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 651 07-08-2022, 03:41 AM
Last Post: 1973cb750
