Instrument Cluster A & B Button Repair
(08-08-2021, 10:58 AM)The ferret_imp Wrote: The question begs why would they be missing? Why was someone else in there?
Crazy.
Good diagnosis and fix!
I can't figure that out either. There are no signs the Instrument Cluster was ever damaged in an accident or something, it all looks original, and everything else works just fine...it's quite the mystery.
Thx Ferret!
BTW Ferret, I think you are only about two hours from me, South/Southwest I think.
Great story! Logically thought out with a positive result.
Since the bike was purchased used recently, the previous owner or dealer would know, since it did not leave the factory that way. If the clock couldn't be set, or the trip mileages reset, it would have been covered under warranty new by the dealer. The reset extension pieces are usually held in by a foam ring and would not drop out by themselves.
The white plastic panel is the structure that holds everything together in the instruments - the covers, the printed circuit and gauges themselves, and the studs that mount it to the top triple clamp. However, it has never been available separately from Honda on any year CB1100.
As mentioned in prior forum threads, there are suppliers of complete meter assemblies without the actual printed circuit and gauges on eBay, but they likely wouldn't include the separate extension pieces or any other small hardware pieces.
(08-08-2021, 04:40 PM)pekingduck_imp Wrote: Since the bike was purchased used recently, the previous owner or dealer would know, since it did not leave the factory that way. If the clock couldn't be set, or the trip mileages reset, it would have been covered under warranty new by the dealer. The reset extension pieces are usually held in by a foam ring and would not drop out by themselves.
Good info PD. I contacted the previous owner and he acknowledged the original owner who purchased new told him he lost the "little pieces" that make the switches work. He did not tell him why he was messing around in the Instrument Cluster in the first place. The seller I purchased it from thought he would have to buy an entire new Instrument Cluster for ~$300 and did not bother with it.
This is the only other source I found for any of the parts which make up the Instrument Cluster assembly:
https://www.motosport.com/oem-parts/hond...1100/meter
The Actuator Rods are available, 2 for ~$33...much more costly than my DIY Rods. Tongue
(08-08-2021, 11:28 AM)pdedse_imp Wrote: Great story! Logically thought out with a positive result.
All positive except the humbling trip on the stairs I took. Confused Big Grin
That's weird... I'd always wonder what happened, but great to hear that you were able to diagnose it and come up with a simple, elegant solution.
(08-09-2021, 02:14 AM)Gone in 60_imp Wrote: That's weird... I'd always wonder what happened, but great to hear that you were able to diagnose it and come up with a simple, elegant solution.
And cost effective! Leaves more money for other, cooler things on the bike. Thumbs Up
I'm impressed:
(a) with your diagnosis and repair; and
(b) you survived tripping on the stairs.
Nice work all round.
I am very impressed that you " pinned" the problem so cheaply .
(08-10-2021, 08:37 PM)Cormanus_imp Wrote: I'm impressed:
It takes real talent to trip going up stairs.
Thx Cormanus! Cool
(08-10-2021, 08:56 PM)Houtman_imp Wrote: I am very impressed that you " pinned" the problem so cheaply .
Wah wah wah...it was really more of a MacGyver operation truth be told. Big Grin
Thx Cormanus! Cool
Thx Cormanus! Cool
Phadreus, now we have a bit more complicated assignment for you: find the OEM push rods Tongue
  Instrument Cluster Needles Cormanus 14 957 02-04-2026, 02:29 PM
  Repair manual for 2017 RS TheLegend 21 2,357 07-10-2025, 05:58 PM
  Hibeam and hibeam flash button acting up. Jgarciajr40_imp 7 741 04-01-2024, 08:13 AM
  flat repair. ‘17 CB1100 EX sleeper_imp 15 1,155 08-29-2022, 06:31 AM
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,914 07-12-2022, 08:04 PM
Last Post: tommymck
  Service and Repair Manual alexzanutto_imp 5 645 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Loose Instrument Panel / cluster ecka00_imp 12 760 06-07-2019, 06:50 PM
Last Post: Bazbro_imp
  Buzzing Instrument Cluster White Dog_imp 41 2,321 09-17-2018, 09:32 PM
  Lower Cover instrument panel linuxology_imp 5 444 11-01-2016, 10:19 AM
  Instrument panel cover removal help Stratus_imp 22 1,273 07-03-2015, 03:15 AM
Last Post: Redbird_imp
