Video: oil and filter change
Hi Scotty, good job.
In total, how much oil did you put in?
(11-29-2021, 03:07 AM)Enzofour_imp Wrote: Hi Scotty, good job.
Hey everybody, thanks for your generous comments. Feels good.
I think I used around 4 quarts. The reason I can't say for sure is that I began with a partially full container and wasn't being too exacting about it.
On that note, I think we/I tend to slightly overfill motorcycles. The CB1100 has unusually large oil capacity to begin with, I suspect it was engineered that way due to it being air/oil cooled. Volume has a lot to do with oil change interval.
For example, my 80 Series Land Cruisers have a reputation for being "very easy on its oil." Well, the 1FZ-FE engine has a good, internal oil cooler and 8 quarts of oil! That's a lot of capacity for a gasoline engine. If it had a 4 or 5 quart sump I doubt it would have its reputation.
But back to the CB1100: it's better to add oil than to be over that upper line when filling.
Finally got around to watching this. What a well edited video. Your camera work was great and your voice was like butter. Strong work!
I asked you this question because I have difficulty checking the level as described in the manual.
Even after 1/2 hour from switching off, the level control window is completely full, only after a few hours, when the engine is completely cold, the level drops to the maximum mark.
Use Motul 7100 10w30 qta 3,8 Lit. with Hiflo filter change
Sounds like you're a little too full. I wouldn't worry about it, but next oil change try starting with less oil and over a few rides top it up. You definitely have good oil and filter. Don't be afraid of 10W-40 if your part of Italy is hot.
... and 5W40 synthetic for cold weather riding below the freezing temperature.
  Oil Filter dave 12 589 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,521 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,816 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 3,014 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,690 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,546 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 962 09-21-2022, 04:02 AM
  Air Filter Change Interval? dave 25 2,002 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,550 09-07-2021, 07:44 AM
  2018 air filter Rogerdj_imp 4 478 08-20-2021, 08:29 AM
