Power Commander Tune Maps.
(08-16-2020, 08:16 AM)PowerDubs_imp Wrote: Yup. I'm pretty sure I was the first...I think a few others have done it since then.
Given the cost of the TSR horns, and the cutting to install those- the factory parts are dirt cheap, and can be swapped back to stock as there is no cutting of anything needed to fit.
What's the final verdict on this? I actually bought a TSR funnel recently but it feels rather heavy. Have not yet installed it but will most likely be running it with a K&N air filter for better air flow.
Just got back from my first 60 mile "flashed" ride. The ECU certainly opened her up.
PCV is next on the list it looks like, then I'll officially join the 100HP club Clap
I can't imagine the K&N will make any difference other than a lighter wallet and more dirt penetration.
When I mentioned TSR horns above, I was talking about their velocity stacks for the throttle bodies which require cutting and modification to install.
https://www.samurider.com/?p=16781
While they *may* give more power up top than DIY on the stock parts...they cost a lot more, and a lot more work to install.
You won't hit 100whp on the stock velocity stacks. May not hit it without cams...nobody has done that yet to my (admittedly out of the loop) knowledge.
(08-16-2020, 10:42 AM)PowerDubs_imp Wrote: I can't imagine the K&N will make any difference other than a lighter wallet and more dirt penetration.
I thought we saw a close 99hp on someone's dyno that did honed out the funnels tho?
Maybe-- I was away for almost 2 years since my accident almost 2 years ago.
If you can find it- I love looking at dyno curves, rpm, tq, fueling, and what mods...
(08-16-2020, 11:19 AM)PowerDubs_imp Wrote: Maybe-- I was away for almost 2 years since my accident almost 2 years ago.
Sorry to hear that, been there myself.
Hopefully you had a full recovery! I thought someone posted it to the thread your write up was on
The stacks are a bit overkill IMO given their design and install process, let alone their outrageous price new.
I was referring to the funnel inlet portion. Speaking of which -seems I got the generic version and not the TSR, anyone know if the missing hole for the sensor would be a problem?
Funny thing is, I'll probably never really know forsure, as I don't intend throwing $500 at it for a proper "dyno-tune"
Next up on my list is the Air system delete, PCV and MAYBE DJ Autotune, BUT THAT'S IT!
At which point, I'd probably also be doing sprockets, suspension, and a steering stabilizer.
One thing leads to the other Rolleyes
(08-16-2020, 11:34 AM)E11even_Hunnit_imp Wrote: The stacks are a bit overkill IMO given their design and install process, let alone their outrageous price new.
Air system delete? Sounds like we wanna do the same things mostly lol
Never been a fan of those canister junks, and their rather useless functionality... typical emissions BS
Is that so? Not so much coincidence as it's pretty much the only path to some power on this bike I guess...
(08-16-2020, 12:26 PM)E11even_Hunnit_imp Wrote: Never been a fan of those canister junks, and their rather useless functionality... typical emissions BS
Do you mean deleting the catalytic?
Negative, I lost that when I fitted my Yoshi full-system.
I'm referring to the air injection valve delete
http://cb1100forum.com/forum/showthread.php?tid=8678
http://cb1100forum.com/forum/showthread.php?tid=1824
  GPS power cable The Gecko_imp 10 1,068 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 521 08-10-2023, 07:20 AM
  Power source for oil indicator led norton1974_imp 1 290 12-31-2022, 10:07 AM
  Dyno jet auto tune sethrose_imp 11 860 10-06-2022, 09:40 AM
Last Post: STLTHMSTA_imp
  Question for the guys w/ auto tune PowerDubs_imp 3 418 10-01-2022, 02:10 AM
  Power Commander V question HBFL_imp 1 269 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  2010 model Power Commander alternative? 83NZA_imp 7 670 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Transmission power routing and speeds LakeWylieJoe_imp 6 685 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Guhl Reflash vs. power commander with custom map. misterprofessionality 9 842 09-06-2020, 03:59 AM
  Cheap airflow / power gains PowerDubs_imp 7 667 07-21-2020, 01:59 AM
Last Post: Cobalt23_imp
